D%#m Mach 460 System - Mustang Evolution
Old 06-23-2004, 10:19 PM   #1
McGrail482's Avatar
Region: West Virgina
Send a message via AIM to McGrail482
Angry D%#m Mach 460 System
Im going to order some new speakers for my doors tom. but i was thinking about it and since the speakers in the doors were starting to fall apart i was going to replace the two speakers in the back...The only problem is i cant figure out how to get to those speakers...Im pretty sure they are 6x8's but if someone can confirm that and tell me how to get to them. I heard 5x7's can fit too but? Also are they all two-way speakers and should i replace them with the same thing or get 3 or 4-way speakers? Last question...Am i going to have to rewire all the speakers?
-Jason
2015 5.0 Mustang
Previously Owned:
1995 3.8 V6 Mustang-True Duals w/Mac Flowpaths, BBK CAI
2012 Ford F150 FX4
McGrail482 is offline   Reply With Quote
Old 06-23-2004, 10:21 PM   #2
Mach 460 is the devil for Aftermarket parts. Never had to deal with it so cant help you there.
Yes 5x7 and 6x8 will work.
Not sure if you have to rewire though. Dont know how the Mach is hooked up
Old 06-23-2004, 10:24 PM   #3
Black95GT's Avatar
Send a message via AIM to Black95GT
Aftermarket speakers dont work with the stock Mach 460 headunit, you need to change that too. Something with the ohms. Normal Speakers you buy are 2 or 4, the mach 460 are 6 or 8, i forget. So you can put it new speakers, but the blown stock speakers will sound better
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 06-23-2004, 10:33 PM   #4
McGrail482's Avatar
im not dissing the system its just when i took the speakers out they looked like they were starting to desingrate (however you spell it) and one was blown so i decided to replace them... and also i have a sony xplod headunit
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 10:40 PM   #5
i dont know how the mach is wired up but i doubt you will have to rwire ur speakers
Old 06-23-2004, 10:47 PM   #6
McGrail482's Avatar
so blackgt since i have a different headunit will the new speakers work?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:04 PM   #7
they should yes
Old 06-23-2004, 11:05 PM   #8
Aftermarket Full Range Speakers are 4 ohms
Mach I dont know about.
Old 06-23-2004, 11:06 PM   #9
McGrail482's Avatar
I am trying to learn car audio but it is really confusing
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:06 PM   #10
The only problem that I would see is how the speaker wiring is set up.
It may be wired to see a different ohm than you need it to.
Look into that before you buy the speakers.
If they are wired normal then yes it will work with your current set up
Old 06-23-2004, 11:07 PM   #11
yea it is. I just need to learn how the Mach 460 and 1000 work. I get everything else lol
Old 06-23-2004, 11:08 PM   #12
McGrail482's Avatar
So would these speakers work?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:10 PM   #13
McGrail482's Avatar
like when i took the speakers out of the doors they are like plugs that go into the speakers not like a pos and neg wires...
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:16 PM   #14
yea crutchfield sells a adapter for that or you can cut the plug off and splice the wires.
I am 95% sure that aftermarket speakers will work. I just dont want to come out and say yes and then for some weird change it doesnt you find me and beat me up
Old 06-23-2004, 11:21 PM   #15
McGrail482's Avatar
Yeah cause im 6'5, 250, and bench about 300.
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:27 PM   #16
Black95GT's Avatar
If you have an aftermarket Headunit, the new speakers will work, you need the adapter to bypass the mach 460 amps.
-Jason
Old 06-23-2004, 11:33 PM   #17
McGrail482's Avatar
Is there an amp in the headunit or something? so i can remove those amps when i get the new speakers?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:34 PM   #18
Black95GT's Avatar
In your sony headunit there should be an amp, so when u get the adapter it will stop the stock Mach460 amps from being used so that the Sony internal amp will be used instead. The sony headunit will power the speakers.
-Jason
Old 06-23-2004, 11:36 PM   #19
McGrail482's Avatar
Will the speakers sound as good, worse, or better than the mach 460
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:39 PM   #20
Black95GT's Avatar
The Mach 460's sound really good for stock, but anything aftermarket will sound way better, since it isnt made of ****ty paper cones.
-Jason
Old 06-23-2004, 11:41 PM   #21
The new speakers will be alot better.
Old 06-23-2004, 11:42 PM   #22
McGrail482's Avatar
Well how much was that stock 460 system pushing? That new headunit says like 60 watts by 4...So is that going to be like 15 watts per speaker...I really dont get this audio stuff...
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:44 PM   #23
Black95GT's Avatar
its a 460 watt system, im not sure if thats max or rms, if its 460 max, the rms is most likly 200-230
-Jason
Old 06-23-2004, 11:46 PM   #24
Black95GT's Avatar
Not matter what aftermarket speakers you get, they should sound way better than stock.
-Jason
Old 06-23-2004, 11:49 PM   #25
60x4 is peak
Your getting about 21rms into each speaker and 60 peak
RMS is the important one to look at
Old 06-23-2004, 11:50 PM   #26
McGrail482's Avatar
Alright thanks alot
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:51 PM   #27
McGrail482's Avatar
Ill prolly have a couple questions in a few though...hahah
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:52 PM   #28
Black95GT's Avatar
this is the adapter
http://www.crutchfield.com/S-HqfDJXg...1&avf=Y&search=
-Jason
Old 06-23-2004, 11:55 PM   #29
McGrail482's Avatar
with that adapter what all would i have to do with it?
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:57 PM   #30
Wait did you have the cd player installed somewhere? If you did it probably already has this.
Old 06-23-2004, 11:57 PM   #31
Black95GT's Avatar
I think you may need the normal wire harnesses to, but that it for the stock amps, Im not sure if it lets you use the amps still or completly stops them. But it has adjustment knobs, for each channel.
-Jason
Old 06-23-2004, 11:58 PM   #32
McGrail482's Avatar
yeah at circuit city
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Old 06-23-2004, 11:58 PM   #33
Black95GT's Avatar
Good question, he may not even need it.
-Jason
Old 06-23-2004, 11:59 PM   #34
Black95GT's Avatar
well if you got the headunit in already, then the speakers should go in just fine.
-Jason
Old 06-23-2004, 11:59 PM   #35
McGrail482's Avatar
from what im reading that adapter is only need when adding a headunit...i must already have that
-Jason
2015 5.0 Mustang
Previously Owned:
2012 Ford F150 FX4
Mach 460 Sound System help Kaleb Mustang Audio & Video 14 01-14-2011 08:08 PM
mach 460 sound system help 968 1996-2004 Mustang GT 16 07-27-2009 06:57 AM
FS: 01+ Mach 460 6 Disc system PureVenom Mustang Parts for Sale and Wanted 13 10-05-2005 05:44 PM
FS Mach 460 system lowflyn Mustang Parts for Sale and Wanted 21 03-07-2005 05:18 PM
Question about the Mach 460 system lowflyn Mustang Audio & Video 20 10-11-2004 07:31 AM
06:10 PM
