Water in Headlight - Mustang Evolution
Old 07-24-2004, 03:54 PM   #1
Send a message via AIM to kaper232 Send a message via Yahoo to kaper232
Water in Headlight
Is there a way to open the head light assembly so I can drain the water out of it and clean the inside of it?
kaper232 is offline   Reply With Quote
Old 07-24-2004, 03:59 PM   #2
I had a fog light that got water in it a while back. Take the head light out and take it inside drain the water out as good as you can and then use a long pencil or something with some sort of debri free (lint free if you can) cloth to clean all you can finish up with a hair dryer to evaporate the water thats left and go back over it and buff it clean. Thats about all i can tell you unless you cut open the head light and you might screw it up doing so. My fog light I just evaportated the water and it cleaned up good as new.
Old 07-24-2004, 05:06 PM   #3
The light does not open up.
However it can be opened with some creativity.
But they are sealed.
But I guess you could remove the light and get out what you could by simply pouring it out where you insert the bulb.
Extreme Effects.com is offline   Reply With Quote
Old 07-24-2004, 05:47 PM   #4
yea and use a hair dryer it will evaporate the remaining mouisture just have the opening facing upward. if your lights are yellowed take this as an excuse to get new black ones or different ones or what ever you want. did you cut them open and remove the corners? if so thats probably why its getting water in.
Old 07-24-2004, 06:02 PM   #5
Danger Dude's Avatar
yes remove the headlight, take out the bulb, pour the water out. Take a hair drier and on hot aim towards the bulb hole and in about 10 min it will be completely dry. Go et some 100% silicone sealant and run a bead around the entire seam of the lens let dry and reinstall.
Old 07-24-2004, 06:59 PM   #6
Fishers Stang's Avatar
yeah thats your best bet, but is this from the water thing you had? but yeah just let them air out.
Charles
Old 07-25-2004, 05:49 AM   #7
Yeah, its from my water damage...
Thanks guys for the input!! I appreciate it!!
Scientists look for water and find... wiarumas The Bar 8 02-22-2007 11:00 AM
water damage??? bluestang1724 The Bar 2 11-25-2006 01:19 PM
water pump ? jumpman1203 Pre-2005 V6 Mustang 0 10-16-2006 12:25 AM
water and mustangs Kyle The Bar 12 05-01-2006 09:21 AM
Bad water spots. Dom Mustang Audio & Video 6 02-19-2005 09:28 PM
04:57 AM
