Need help asap (stereo question) - Mustang Evolution
Old 12-19-2008, 05:04 PM   #1
Ok putting in aftermarket Alpine Head unit, i hook it up red to red black to black yellow to yellow, then speaker wires of course but it wont give my head unit any power. Anyone have any insides on what i should try or do its all brandnew stuff so iunno
02slowgt is offline   Reply With Quote
Old 12-19-2008, 10:58 PM   #2
DaDant!'s Avatar
Re: Need help asap (stereo question)
did you get the wiring harness for your alpine?
check the fuse under the hood, i blew mine when i installed my headunit.
how did you connect the wires, did you use like wire screws the ones electricians use for like ceiling fans, use wire crimpers or just put electrical tape?
if its not the fuse, double check the connection of the wires, if thats not it i recommend taking your car to an audio shop and having them take a look at it.
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Old 12-20-2008, 05:34 PM   #3
Before you answer anything else...
Does your car have either the Mach 460 or 1000 system factory?
Old 12-20-2008, 05:46 PM   #4
The reds and the yellows should be separate. The red is switched power and the yellow is constant power. The head unit should have a yellow for constant power. Use a 12V test light and test to see which is the wire from your switch and verify that the yellow is hot always.
qtrhoss13 is offline   Reply With Quote
Old 12-20-2008, 10:07 PM   #5
DaDant!'s Avatar
low, i have the mach 460 and an alpine unit i installed it my self, as long as he has both wiring harness he will be good, lol
im getting there.
Old 12-20-2008, 11:07 PM   #6
I wanted to make sure which wiring harness he had...if he doesn't have the right one it'll be all screwed up. I know...been there.
Old 12-21-2008, 04:25 AM   #7
DaDant!'s Avatar
true i understand that. i think the problem might be that he blew a fuse if he did get the correct one. cause when i did my install i blew the fuse and i wasnt gettin any power to my head unit and i know i hooked it up right.
im getting there.
Old 12-23-2008, 11:27 PM   #8
Thomas91169's Avatar
****can the entire mach460 garbage setup and opt for components all around. The mach460 is a 9v setup, whereas your new deck is a 12v. Sure it will work, but it will make the system way too sensitive towards the standard deck, to where the volume level 5 is unbearably loud.
Honestly id get the ford to aftermarket power harness so your power and everything is pretty much plug and play (you just have to wire up the converter harness into the Alpine's harness) and then go to town on rewiring the rest of the speakers. Youll be glad in the end, i had the Mach460 in my 02 GT and went to a CDA-987X, Alpine components up front and Alpine 5x8/5x7 triaxials out back (still in the mach decklid though, you can also put components in there as well) and the entire setup sounded light years better than the Mach460.
-Thomas-
Halo Projector light question need help asap StangPride Pre-2005 V6 Mustang 5 03-25-2009 01:39 AM
stereo question white98gt 1996-2004 Mustang GT 16 11-15-2008 04:53 PM
Need help asap with Stereo install Scorpion1 Pre-2005 V6 Mustang 13 07-10-2008 01:34 AM
mp3 stereo question Monkey The Bar 6 10-08-2004 05:55 PM
quick stereo question Monkey Mustang Audio & Video 4 07-06-2004 12:00 AM
06:51 PM
