Removal of Belt Holder - Mustang Evolution
Old 08-04-2004, 02:14 PM   #1
Hey fellas.
I tried taking the belt holder that is attached to the seat and I just got so annoyed I stopped. Its looks very easy but I just wasn't able to. Maybe its something so easy and I am clueless.2:
Does anyone know the easiest way to remove them?
Thanks.
robert0803 is offline   Reply With Quote
Old 08-04-2004, 02:49 PM   #2
97Stallion's Avatar
There are two tiny screws under the head rest, you need one of those z shaped screw drivers.
Living one day at a time!
Old 08-16-2004, 10:40 AM   #3
steedav6builder's Avatar
Send a message via AIM to steedav6builder
Yep thats what i used.
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Old 08-16-2004, 02:30 PM   #4
I have had no luck finding one at the hardware store. I have asked a couple of my buddies and they no clue what a "z shaped scredriver" is..
Is there another specific name I can use to look for this tool.
Thanks.
Old 08-16-2004, 02:53 PM   #5
97Stallion's Avatar
Um, is there technical name, i have no idea. That's just what everybody calls them. it's piece of steel rod basically, and at both end it's bent 90* in opposite directions and the end has a phillips or flat head. I'll see if I can get a picture or something.
Old 08-16-2004, 03:35 PM   #6
yea the one i have is a philips on one end and a straight screw driver on the other. idk what it would be called. its just for workin in tight spaces.
Old 08-28-2004, 12:11 AM   #7
BlueThunder's Avatar
I got one of those wrench key sets @ Autozone yesterday.The bits are star shaped and it has 7 key wrenches in it(it's pocket sized)The technical name I don't know...but the one I bought is called a drivemaster key set. It ran me about $7.I have seen these at several auto part stores around my area so that would be my suggestion for you.
Hope this helps you out!
BlueThunder is offline   Reply With Quote
Old 08-28-2004, 06:50 AM   #8
fast64's Avatar
i used a 3.5mm hex key to take mine off
GO BRAVES
Old 08-28-2004, 07:03 AM   #9
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
allen wrench, right?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 08-28-2004, 11:35 PM   #10
___________________________________
Close....but the tip looks like a star w/ 6 points on it.
Old 08-29-2004, 09:18 AM   #11
Rick0636's Avatar
I believe you are talking about torx drivers? I have some, the come in sizes like T-10, T-15, T-20, etc. You can get them in bits and things that will fit on a ratchet too.
Old 08-30-2004, 06:45 AM   #12
Danger Dude's Avatar
The z shaped screwdrivers are called " Offset Screwdrivers" Actually Sears and some Auto places have Ratcheting Offset screwdrivers. I have one that is made by Snap-on but Sears sells the exact same thing.
Old 08-30-2004, 11:13 AM   #13
I've got to get one of those..my driver side is about to fall off lol
Old 08-30-2004, 11:49 AM   #14
I'm not sure if it will work for all cases...but something I did made it real easy to take them belt guides off was this.First I took out the first screw closest to the door and then for the second screw( the hard to reach one) I turned the belt guide counter clockwise until the screw came loose.After that I used the guide like a ratchet and turned the screw the rest of the way(use finger to hold pressure on screw and slightly raise the guide during the c/c turn)
And that's the story of how I got my seatbelt guides off....Enjoy!
Old 08-30-2004, 12:14 PM   #15
Yeh..but then you gotta get them back on....lol
Front License Plate Holder/Bracket 99 SVT Cobra 1996-2004 Mustang GT 4 03-16-2010 04:11 PM
Center Console n Cup Holder 98MustangGT 1996-2004 Mustang GT 2 06-23-2008 08:13 AM
smog pump removal.. Belt size? GTOWNR 1979-1995 Mustang GT 9 05-04-2007 06:10 AM
Head Rest Removal/ Seat belt relocator cagedthought Mustang Audio & Video 14 12-04-2004 01:08 PM
04:36 AM
