Sub install with Stock stereo, Help please. - Mustang Evolution
Old 02-03-2009, 10:26 PM   #1
Renegade 800's Avatar
Region: Idaho
I installed an amp and sub and I used the High level inputs on the amp. The problem is when power is turned on there is a loud "Thump" Also when I hit the brakes and use the turn signals. I tried a line level converter and used the RCA inputs and it does the same. It is really annoying. I unplugged the sub for now. I am sure the amp has a good ground so I am at a loss. The converter is a cheap one so maybe I will buy a better one. I don’t know what else to do. Any thoughts?
I am not sure what stock radio I have. I think there is an amp under the CD player. No sound from the radio with out the CD player plugged in. 2000 Model with the split radio/CD Player.
Renegade 800 is offline   Reply With Quote
Old 02-04-2009, 06:01 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Sub install with Stock stereo, Help please.
In my 2001, the sub would make a "thump" when the amp was turned on. I just chalked it up to a small surge of power going through the amp and into the sub. The sub will react to an electrical signal it gets. It also happened every time I shut the amp off.
Old 02-04-2009, 03:44 PM   #3
Region: Idaho
I can deal with the turn on and off thump, it is the brake and turn signal that is driving me crazy.
Old 02-04-2009, 03:54 PM   #4
Are you using a FM modulator to run the amp? Also, are you running the RCA's and power wires on the same side of the car or relatively close to each other?
Old 02-04-2009, 04:13 PM   #5
It sounds like a bad ground somewhere to me. Low is right in that if you use low quality RCA cables and run them along side power wires, noise will bleed into them, but it sounds like you aren't running RCA cables at all now.
I'd check the grounds, on everything, the amp, the factory stuff, hell the battery under the hood. What amp/sub are you running anyways?
ThaWill is offline   Reply With Quote
Old 02-04-2009, 04:56 PM   #6
Region: Idaho
Correct I am not running RCA’s at the moment. I did run the Power on the driver’s side. The remote turn on is coming off the power from the radio and is running down the middle under the carpet. I did run Some RCA for the future when I get a replacement deck on the left side of the car.
The amp and sub is a lightning audio set up, I got It new for $90. I am on a budget, I wasn't even going to get a sub until I ran across this.Lightning Audio® : Product Details
There is no thump when I unplug the inputs. It does sound like a bad ground to me also. I will check them again.
Old 02-04-2009, 04:59 PM   #7
I would recommend getting an FM modulator and tapping into the rear speakers to get your input, that will help clear up sound.
Also, make sure the amp is securely grounded. I ended up tapping a new spot behind the carpet on the driver side in the trunk and grounding my system that way in my last mustang. Never had a problem with it.
Take some sand paper and get it down to bare metal beforehand.
Old 02-04-2009, 08:44 PM   #8
Region: Idaho
FM Modulator? I am not trying to hook up an Ipod. Do you mean one of these?
Scosche Factory OEM Interfaces Hi/Lo Line Level Interfaces SPKR LEVEL CONV 80W at Scosche.com
Old 02-05-2009, 05:35 PM   #9
DaDant!'s Avatar
this should help
fm modulator - Google Product Search
edit. fm modulators are used for factory headunits that do not have RCA output. basicly it is used to send the signal to the amp where otherwise you could not w/o the RCA. to sum it up it is an adapter. (if i am wrong some one will not hesitate to correct me)
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Old 02-05-2009, 07:23 PM   #10
Region: Idaho
The FM modulator is for RCA "Input" Not Out. I bought the Scosche line converter I posted above and that did the trick.
Old 02-05-2009, 10:04 PM   #11
I dunno why I have FM modulator stuck in my mind. I started looking it up last night and my neighbor's internet died....
Old 02-06-2009, 10:00 AM   #12
DaDant!'s Avatar
congrats.
im getting there.
Old 03-22-2009, 09:42 PM   #13
upton7's Avatar
i had a thump thing goin on in my 01 i got a new cd player and it worked fine oh
Need help asap with Stereo install Scorpion1 Pre-2005 V6 Mustang 13 07-10-2008 01:34 AM
2001 gt mach stereo sub & amp install gwilkrrs Mustang Audio & Video 2 07-08-2008 06:09 PM
Complete Stereo Install! onetwin69 Mustang Audio & Video 2 03-27-2007 07:36 AM
2000 mustang stereo install?? stang00 Mustang Audio & Video 11 01-03-2006 02:28 AM
How to on stereo install lowflyn Pre-2005 V6 Mustang 4 11-13-2003 06:43 PM
06:16 AM
