Working on a high power system but need insight....HELP A MAN OUT PLEASE?!!!! - Mustang Evolution
Old 10-15-2004, 09:44 PM   #1
BlueThunder's Avatar
Question Working on a high power system but need insight....HELP A MAN OUT PLEASE?!!!!
Alrighty then....So I've been working on getting all the materials ready to drop one hell of a trunkshaker into ma pony but I need some additional insight into what else I may need to ad in order to get this baby rockin!
For starters I got ahold of an Pyle Audio Eternal Series 4270 1600watt 4 channel amp and a Pyro Audio 2.5 Farad Capacitor w/wiring kit.I have a JVC KD-S670 single disk cd dash unit with rear line-out RCA ports (45wX4)but am not sure if it can hold up to this sort of beating(power-wise).I haven't bought my bandpass/subwoofer box yet.Though I'm pretty certain I will go with 12"ers because it's appropriate for that amount of juice.Guess my dilemma is....amp/cap.wiring ,using distribution blocks,and overall the best suitable way to (mount) this bassbomb!
I am pretty sure I will end up getting an Optima Yellow Deepcycle battery under the hood($169 w/ trade-in..OUCH!)but would be better than having to replace the alternator,right?About wiring....anyone have any ideas about wiring both an amp AND a farad cap.?Which would be better...a distribution block or direct wiring it to the battery?Doesn't leave much post room on the battery having both the car and the amp AND the cap all hooked to one post but I guess it might be possible?Also,isn't there additional grounding work that has to be done in order to make the set-up safe?I had also planned to hook the remote-on wire into a switchpanel either in the dash console OR in the armrest(depending on how many switches I expand to later on for other goodies)Above is what I got....if anyone has some concrete info to offer about how I can Git-R-Dun then please feel free to fill in the blanks!
Thank You all in advance,
Thunder
BlueThunder is offline   Reply With Quote
Old 10-15-2004, 10:36 PM   #2
capacitors are not worth the money for starters
I have 2 gauge wire (all you need) going into a 4 gauge out distribution box which then goes to your amps. It grounds 4 gauge to the car and you are set.
power window not working rob913 1979-1995 Mustang GT 5 08-21-2010 11:28 AM
Power Windows Global Access NOT working after SJB replace - Is this fixable? HOW? bighank General Mustang Discussion 0 09-30-2008 05:26 PM
Passenger Side Power Window Not Working louie7600 General Mustang Discussion 1 07-27-2008 07:36 PM
charging system not working muskrat Classic Mustangs 8 04-12-2008 09:50 PM
Climate Control System Not Working mach232 Pre-2005 V6 Mustang 9 12-15-2004 07:33 PM
06:36 AM
