Stereo ground wire location - Mustang Evolution
Old 10-19-2004, 07:55 PM   #1
Send a message via AIM to Crispy
Im gettin the alternator whine through my system, it happened after I hit a bump and i've re-wired the system, got new signal cables, scraped the metal touchin the ground point and i'm still gettin the noise. I have the amps grounded just under the head rest, im nto able to take pix right now since i dont have a cam.
If you remove the head rest, you get 4 bolts goin across the top that hold the rear seat bracket in place, i have it grounded there, its touchin only metal. My question is where do you guys have your system grounded? Would you suggest a different spot?
Crispy is offline   Reply With Quote
Old 10-19-2004, 08:25 PM   #2
chips's Avatar
Send a message via AIM to chips
i drive an f-150, so it'll be a little different.
i have my amp grounded to a bolt under my seat. the bolt is attached to the railed that my seat slides back and forth on.
the only reason Dr. Dre produced "The Chronic" because the bible tells you to smoke lots of pot, and Oedipus used to blaze with the makers of Aqua Fresh tooth paste.
chips is offline   Reply With Quote
Old 10-19-2004, 10:29 PM   #3
i have it in the exact same place and there is no problem
Old 10-19-2004, 11:16 PM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
Grounds are funny. I would re-wire the speakers themselves next. Go over every little bit. Make sure the power cable isn't near the speaker wire too.
Old 10-20-2004, 12:02 AM   #5
I have mine grounded on the driver side in the trunk behind the little cardboard side panel. Nice little screw there for grounding in my 02 lol
New job/location Scut95 The Bar 8 06-06-2008 12:40 AM
Need to know location for main engine ground asap... DarkShadow Pre-2005 V6 Mustang 4 08-08-2006 03:02 AM
Stereo wire? 19ClearCobra96 Mustang Audio & Video 13 03-21-2005 04:18 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 03:00 AM
Location Location Location Ken The Bar 9 08-07-2003 09:51 AM
04:27 AM
