Help! Remote wire color - Mustang Evolution
Old 10-27-2004, 12:52 PM   #1
BuddyLee's Avatar
Im installing some subs this week on my factory stereo, and i need to know what color the remote wire is... does anybody know?? thanks
out with the old: 93 turbo integra
in with the new: 03 mustang
BuddyLee is offline   Reply With Quote
Old 10-27-2004, 12:58 PM   #2
Zim
You want to **** me?
Zim's Avatar
blue
I like toys
Old 10-27-2004, 01:08 PM   #3
Originally Posted by ZimStang
blue
On factory?
So your installing subs on your stock headunit?
Old 10-27-2004, 01:23 PM   #4
BuddyLee's Avatar
thats right. with a line output converter.
im also considering just wiring up a switch instead of a remote wire. what would be a good power source for that? thanks
Old 10-27-2004, 01:33 PM   #5
You can tap into the head unit power or just look in your fuse box for something that comes on when your car does, like the fuse for the cd player, put the wire in the hole, push the fuse back in and you have a remote wire
Old 10-27-2004, 01:34 PM   #6
And don't just wire up a switch, it'd be stupid when you can just do it the way I said and it be done, no more wires to run. Let me know how the install goes with the line converter, I gotta get outside and do mine...after taking my stereo apart to unhook the amp...
Old 10-27-2004, 02:58 PM   #7
BuddyLee's Avatar
i know it would be easier to wire the remote wire, but the reason i was thinking about a switch was in case i ever wanted to jam without my subs on. just a thought
Old 10-27-2004, 03:02 PM   #8
Just reach in the trunk and turn your amp down. I thought about the same thing when I first started in subs...you never want to do that once you get them lol
Old 10-27-2004, 05:22 PM   #9
BuddyLee's Avatar
im too lazy to do that, haha. ive had subs in my past two cars, and i installed them myself, some of the music i listen to gets really annoying with heavily accented bass.
someone else told me that the remote wire is black with a pink stripe. anybody know for sure?? i have a non-mach system.
Old 10-27-2004, 05:32 PM   #10
Hm...I could go outside and look..but...I can tell you exactly where it is...
I'm looking at my aftermarket adapter, look at the connector with the clip side up. The bottom left wire is the constant power wire, the second from the left on the bottom row is the accessory wire. That's the one you need to hook up to. Hope this helps. Get a piggy back connector, one that clips onto the existing wire and simply adds another wire to it.
Old 10-27-2004, 05:56 PM   #11
just tap into the ignition wire behind the head unit, it would be a good remote
Old 10-27-2004, 06:27 PM   #12
Just get a aftermarket head unit.... makes life alot easier
Old 10-27-2004, 07:25 PM   #13
BuddyLee's Avatar
i wish i could afford it, but im a broke college student. and ive had enough decks stolen to be happy with the stock one.
thanks lowflyn, that will work.
Old 10-27-2004, 07:30 PM   #14
I think we're talking about the same thing. There's a constant power wire (keeps everything you've saved on memory) and an ignition/switched 12 volt wire that only recieves power when the head unit is on. That's the wire I described for him to use and tap into. I tapped into the same exact wire on mine and it works perfectly fine.
Old 10-27-2004, 08:09 PM   #15
BuddyLee's Avatar
^^thats the correct wire. otherwise, the amp would be powered whenever the car is on, not just when the head unit is on.
Old 10-27-2004, 08:10 PM   #16
Yup yup so right. I've fixed several ppl's stereos that were like that.
Old 10-27-2004, 10:29 PM   #17
yep thats what im talking about
Old 11-17-2004, 08:59 PM   #18
The colour of the remote wire is blue with a white line.
TheMustangKid is offline   Reply With Quote
Old 03-12-2005, 07:48 AM   #19
02BLUE_STANG's Avatar
Send a message via AIM to 02BLUE_STANG
blue OR!!!! red its the thinest wire in the kit usually it is blue but there are some kits where it is red
02BLUE_STANG is offline   Reply With Quote
What color is your stang and why did you choose that color? Brent The Bar 67 07-12-2016 05:49 PM
power wire? tylbrune Mustang Audio & Video 2 02-16-2010 12:10 PM
Wire tapping... DarkShadow The Bar 11 05-13-2006 09:52 PM
Stereo wire? 19ClearCobra96 Mustang Audio & Video 13 03-21-2005 03:18 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
10:34 AM
