How to: Roll Bar (light bar install) - Mustang Evolution
Old 10-28-2004, 04:38 PM   #1
Send a message via Yahoo to cagedthought
I was wondering if anyone knew how to install a light bar?
James
cagedthought is offline   Reply With Quote
Old 10-28-2004, 06:28 PM   #2
What do you mean by a light bar?
Old 10-28-2004, 06:34 PM   #3
97Stallion's Avatar
Do you mean for a vert?
Living one day at a time!
Old 10-28-2004, 06:35 PM   #4
Not that hard, took me about two hours total to mount and wire the brake light.
Just follow the directions int the package. You'll need a drill, and not a battery powered one. Drilling into the frame takes alot of juice.
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 10-28-2004, 11:29 PM   #5
You aren't kidding...I installed my strut tower brace 2 weeks ago and it took 2 days. Needed to drill and tap 6 holes....could only get through about 2 on each charge (with a 12v drill). Drill some, charge, drill some, charge, tap some, charge, etc. Took forever.
I will be installing my light bar (bar without a light though) in the next couple of weeks. Can't see it being too difficult though. Seems pretty straight forward.
Old 10-29-2004, 10:20 AM   #6
Thanks for all the info. im going to install it tonight ill let you know how it goes.
James
Old 10-30-2004, 02:29 AM   #7
Dom
Dom's Avatar
Send a message via AIM to Dom
Your drill sucks. You can build a small house with mine.
Old 10-30-2004, 03:14 PM   #8
Wasn't mine...it was a friends that I had to borrow. All my tools are back in NY until next weekend. And yes, it did suck.
Old 11-01-2004, 12:43 PM   #9
I own a 2001 mustang V6 stang and i just installed a light bar.
how do you remove the head rest?
how do you re-locate the seat belt holder so that it doesnt hit the light bar?
thanks,
james
James
Old 11-01-2004, 12:53 PM   #10
thanks,
james
How far back do you lean your seat? I have never heard of issues with the head rest hitting the light bar. As for the holder, I assume you are refering to the goofy loop that the belt goes through. Just take it off it is in the way. It really serves no purpose other than annoyance at times.
Old 11-01-2004, 01:07 PM   #11
thanks,
james
It was included in my instructions that you have two choices.
You can remove, cut to shorten, drill and remount the seat belt loops.
- or -
You can do what I did and bend them upward to clear the bar.
Old 11-01-2004, 03:14 PM   #12
when you say bend upward , do you mean bend it upward permanently? or just bend them far enough so that the seat can rest back? in any event its becomes annoying bending it back and forth.
do you know how to remove the head rest ?
James
Old 11-02-2004, 09:18 AM   #13
You bend it once, in the upward position to clear the bar. You don't bend it back and forth.
Remove headrest? Pull upward sharply. There's a spring loaded bracket retainer inside the seat that slides along the headreast shaft. When you pull up on the headrest, the retainer slips into the detent, holding it in place.
Lower the headrest down, grab with both hands, and pull up sharply to get it past the detent.
92 gt conv roll bar onequickR 1979-1995 Mustang GT 2 02-17-2009 06:45 AM
65-73 NOS Mustang Adjustable Rear Anti-Sway Roll Bar MyStylesTheBomb Mustang Parts for Sale and Wanted 0 08-01-2006 02:57 PM
Reccomendation: Do NOT install a Light Bar mexor The Bar 3 07-24-2004 10:52 AM
Installing Light Bar Smokedya95stang The Bar 10 07-20-2004 11:31 PM
12:30 AM
