Bronx Rookie - Mustang Evolution
Old 03-17-2009, 03:40 PM   #1
Bronx Rookie
Hey everyone. This is a great site and I just want to say whats up. Im a club DJ. I drive a 2000 mustang v6. Super clean and only 45,000 miles from Florida. Ill be investing in some rims and accessories real soon so I need all the help i can get as I do not know much about anything. Thansk all.
ecash is offline   Reply With Quote
Old 03-17-2009, 04:03 PM   #2
Re: Bronx Rookie
welcome, rims are a great early purchase, really dress up the stang.
Don't hesitate to ask any questions, there's always someone willing to answer them...that's what we do here!
Old 03-17-2009, 04:29 PM   #3
Re: Bronx Rookie
Thanks Ill be in touch. Im looking to spend around 800 with tires if thats possible for 18". Ive been reading about offsets and tires rubbing so Im a little intmidated by all this. also would 18's be a bad Idea since I drive to work and u know about NY roads they are pretty bad. I like the 17's but the 18's look sooo much sweeter IMO.
Old 03-17-2009, 04:56 PM   #4
Cobra GT's Avatar
Re: Bronx Rookie
welcome to the site
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 03-17-2009, 05:04 PM   #5
Re: Bronx Rookie
17" SVT RIMS
255/45/17 FUZION tires Will these fit a 2000 V6??
Old 03-17-2009, 06:44 PM   #6
Re: Bronx Rookie
As long as the bolt pattern is 5x4.5 and the backspacing is around 5.9in (151mm) to 6.02in (153mm), you should be fine. The tire size sounds about right to. The biggest issue is the bolt pattern, the 05+ are different, making the wheels tuck in a lot on 99-04's.
I hear ya on the 17's vs 18's. I wanted 18's really bad, but the tire cost pointed me towards 17's.
You shouldn't see any serious rubbing issues with a 17inch tire. Maybe some rubbing at full lock, but that would be about it. I have 245 fronts, and they barely rub at full lock.
Old 03-18-2009, 04:30 AM   #7
bbunt302's Avatar
Re: Bronx Rookie
The height of the rim isn't what's going to cause you're rubbing unless you're talking about putting taller than stock tires on there. It's the width of the rim and tire you have to worry about it.
Still, you should be able to fit 275's on a 9" rim on a 99-04 without having to worry about rubbing much. It may rub if you turn the wheel to full lock, but that's easy enough to solve: Just don't go to full lock.
The only downside to 18s is the ride may be a little more harsh and tires are crazy expensive. Which has never made sense to me considering they are less rubber than a 17" tire in the same size... :dunno:
Scary stuff.
Old 03-18-2009, 09:18 AM   #8
Re: Bronx Rookie
on 03 and 04 mustangs they took out a little bit from the frame to clear the 275 wide tires on the 17x9 rims they used on the 03/04 cobra. They still work fine on 99-02 Mustangs but you may rub a tiny bit, its not bad at all.
Old 03-18-2009, 08:26 PM   #9
1234's Avatar
Re: Bronx Rookie
Welcome
Old 03-19-2009, 12:25 PM   #10
Herbstang's Avatar
Re: Bronx Rookie
Welcome To M.E.
Old 03-19-2009, 02:43 PM   #11
hottcobra's Avatar
Re: Bronx Rookie
Old 03-19-2009, 03:41 PM   #12
wiarumas's Avatar
Re: Bronx Rookie
welcome
« new to this | hi!!! »
rookie pony driver here. needin a lil input from the vets dennyray04v6 Pre-2005 V6 Mustang 11 01-12-2008 08:46 PM
Rookie Howitzer at7311 The Bar 5 05-16-2007 02:15 PM
04:50 AM
