cobra mustang quad cam engine - Mustang Evolution
Old 06-18-2009, 05:29 AM   #1
i have a 1999quad cam 32 valve new engine fitted into an 2009 ac ace ,mileage is 888 miles,i need to change oil and filter,could you please tell me which grade of oil and wether it is synthetic or semi synthetic ,,also could you tell me at what rpm does the quad cam red line safely..many thanks mark kendall(uk)
kendall is offline   Reply With Quote
Old 06-18-2009, 07:12 AM   #2
Re: cobra mustang quad cam engine
Engine/Drivetrain
Engine Displacement: 4.6L 281cid DOHC Modular
Compression Ratio: 9.85:1
Horsepower: 320 hp @ 6000 rpm
Torque: 317 lbs-ft @ 4750 rpm
Originally Posted by http://www.moddedmustangs.com/forums/99-04/324-basic-99-01-cobra-tech-faq.html
99 and 01 Mustang Cobra FAQ Basic Info
Q. What is different between the 99/01 and 96-98 4.6 4 valve engines?
A. The 96-98 mustang cobra comes with a 281 cube 4 valve engine. It sports an aluminum block with a 3.55 bore/3.54 stroke. This block has 6 bolt main caps and is cast by Teksid in Italy. This block also has jack screws (to positively locate the main caps from the side) and smaller side bolts that go through the jack screws. The forged crankshaft is a kellog piece and has an 8 bolt flywheel bolt pattern. The powdered metal rods and hypereutectic pistons are the weak points. The pistons have a 3cc dish. The 96-98 is also equipped with the B heads. They are also known as swirl port heads. These heads have 2 intake ports per cylinder, with an Intake runner control (IMRC) to block off the secondary intake ports until the engine reaches 3250 rpm to promote torque production. The camshafts produce a touch more lowend power then peak power to make the engine more responsive down low. The long runner intake is a 2 piece unit with a sidemount dual 57mm throttle body.
The 99/01 motor has a very similar bottom end. The only differences include larger side bolts with no jack screws, a different sized knock sensor bolt, and the possibility of a different block. The new block is the Windsor Aluminum Plant block (wap block for short). This block has visible ribbing that looks stronger, but the case itself is thinner, making it 5lbs lighter, but weaker overall. The teksid block is the one to have, but the wap will still stand over 700bhp (I have been over this level for more than a year with a wap block). The heads are single port, tumble port “C” Heads. They have a smaller intake port and larger more oval exhaust port in order to make the engine more responsive. The cams are ground more for top end power. The 2 piece intake also has a side mount 57mm throttle body and long runners for torque production. The timing gear is pretty similar with slight differences. The valve covers and timing covers are different. The ignition on the 99/01 motor is a coil on plug system vs 2 coil packs and plug wires on the 96-98. The COP system delivers a stronger spark with less maintenance.
Q. What spark plugs should I use on my 99/01 motor?
A. That depends greatly on the setup. For a basically stock motor, the factory spec’ed plug is a platinum 32 series motorcraft plug. While decent for long life, its not necessarily a performance plug. A switch to copper will give better performance, a cheaper price, at the cost of having to change plugs more often (about every 30k miles). Copper replacements for the stock heat range are Autolite 764s, and ngk tr55s. Do not use the bosch platinum series (either 2 or 4). The recommended gap for naturally aspirated applications is .052 to .056
For wilder setups making over 300rwhp, it might be necessary to go to a colder plug (also for those in very warm climates). The 1 step colder plugs would be the NGK tr6 or I believe the autolite 103 plugs. Ford makes a lovely 1 heat range colder copper plug called the awsfa-22c. this is often regarded as the holy grail plug.
For blown cars with under 10psi, the 1 heat range colder plugs will work well. Start the gap at .035 and make it smaller if you are blowing out the spark (misfires under boost, lots of grey smoke, loss in pull)
For blown cars with higher boost levels, 2 heat range plugs may be needed. These are NGK tr7s or awsfa-12c plugs. I personally run the 12c plugs at a .028 gap with a completely stock ignition. They have been working well.
Q. What exhaust should I run on my 99/01?
A. Tricky question due to personal preference on powerband and sound. There are 3 exhaust categories. 1. Headers, 2. mid pipe, 3 catback. For headers, you can either get shorties, mid lengths or longtubes. Shorties will make the least torque, but are smog legal. They are all a ***** to install, so it won’t make much difference. The only shortie headers to get are JBA. The 1 5/8th size is best for most cobras. FRPP shortie headers are absolute garbage and a waste of money. As far as I know, only bassani makes midlengths and there isn’t that much info on them. If I were going to go to midlengths id go all the way to long tubes. Long tubes have low ground clearance and many brands (aside from hooker and kooks I believe) will require loosening to remove the transmission. Long tube headers will provide a nice boost in low end torque and slightly better gains then other headers up top. DO NOT BUY MAC HEADERS, AND IF YOU DO, CLEAN THE INSIDES OUT VERY WELL BEFORE.
Mid pipe is a toss up. Some like x pipes, others h pipes and others the prochamber. The bottom line is that they all have very similar power gains (about 10rwhp or so) so buy what you think sounds the best.
As far as catback, its pretty much like the midpipe. They all give fairly modest power gains so go with what you think sounds the best. Keep in mind that these will need to be specific to the 99/01 because of the rear suspension so something from and older model won’t fit.
Q. Oil and Oil filter?
A. This question is dependant on both climate, wallet size, and driving style. The spec’ed oil for 99 cobras is 5w-30. For 01s its 5w-20. It will not make a difference which ones you use. Since all these cars are out of the factory warranty, use whatever one is easier to find. If you live in a very hot climate and like to beat on the car, go for something a little thicker. If you live in a cold area, get a thinner oil in order to get the valvetrain lubricated quicker. Do not run anything thicker than a 10w-40. This is not your buddies small block chevy with bearing clearance so thick you could shove a pen through it. You can’t run such thick oil on a mod motor. If you want to get the absolute best oil, go for either german castrol (says made in germany on the back) or amsoil. If you have a midrange budget, get mobil 1 or royal purple. If you want synthetic but don’t have a ton of cash, valvoline or castrol syntec is ok. If you don’t care, put some normal dino oil in.
Oil filters. There are many on the market. All of them are ok except for FRAM. FRAM is junk and the only place it should be is on your lawn mower. The most popular are the Motorcraft Fl820s filter, the K&N one and the Mobil M1 filter. Ford and Wix are the only two brands to have a drain back valve, I would personally ONLY use OEM Ford.
Oil change frequency and oil level are too controversial so I’ll only tell you what I do. I change my mobil 1 synthetic at 3k miles and run 7 quarts.
Q. What size are our injectors?
A. All modular cobras until 03 run high impedence 24lb injectors. The 03 runs 39lb injectors. All aftermarket injectors have the 96-98 electronic plug. PHP and CPR as well as a bunch of vendors sell adapters to run larger injectors on our setups. 60s are the largest, most readily available high impedence injectors. They also offer good driveability. The Stock computer can not run low impedence injectors without a driver. This is expensive and kind of useless since 60s will support about 700rwhp. Standalone fuel systems like FAST or DFI can run both low and high impedence.
Q. What temp is the stock thermostat
A. Right around 195 degrees
Q. What are good easy bolt ons?
A. Underdrive pullies, a cold air intake, exhaust, gears, a timing adjuster or tune, and a ported intake work well.
Q. What are useless bolt ons?
A. Throttle body and maf are ones that 90% of cars don’t need.
Q. I want to do cams on my basically stock cobra, good idea?
A. No, it’s a bad idea. Cams are expensive (900), they usually require springs (600) and are a pain to install (800), so they are not a good idea. They don’t add much power on a basically stock cobra and are really a mod to do after you’ve done bolt ons.
Q. My engine squeaks when cold?
A. Most likely a belt tensioner pulley bearing. Also possibly an idler pulley bearing (1 on a 99, 2 on an 01). Go to a local bearing shop and have them pop a new NTN 6502 bearing in. should cost about 5 bux and you’re set.
Q. My engine won’t idle/dies when I come to a stop/or revs up when I push the clutch in.
A. 90% of the time this is caused by a dirty or faulty Idle air Control (IAC)motor. This is the silver canister located on the passenger side of the intake right by the throttle body. It is held on by 2 8mm bolts and an electrical connector. To clean, take it off, spray it with brake cleaner and either swish it around or use a q tip to clean it. If that doesn’t work, try replacing it. About $80 at ford, around 60 at parts store. Quality of parts store parts unknown.
Q. My engine runs crappy, low power, and backfiring?
A. Try cleaning the maf. It’s the electrical sensor located right after your air box. It requires a tamper-proof torx bit to remove and electrical cleaner to clean. You can figure out the rest.
Q. What should my fuel pressure be at idle, cruise, and WOT?
A. Fuel pressure is always delta pressure- (manifold pressure/2). So at idle, you should see about 20 inches of vaccum. Delta pressure is 39 psi, so you should see about 30 or so psi at idle. This works for all varying levels of throttle. At WOT or zero vaccum, you should see 39psi of fuel pressure.
Q. What should my oil pressure be?
A. the stock oil pressure gauge is useless. Its an on/off switch that reads 60% pressure over 6 psi and zero below. On an aftermarket gauge, you should see about 90psi at cold start. 25 psi at hot idle, and above 75 at 3000rpm cruise. Ford specs are 20 to 45 psi at 1500rpm.
Q. When on the highway at around 2000rpm and I let off the gas, and then get back on it quickly, i get a clunk, what is that?
A. That is most likely the backlash in the gears. They tend to be a little sloppy in stock form so they can clunk on transition from coast to drive.
Old 06-18-2009, 08:05 AM   #3
SaleenFiend's Avatar
Use 5w20 Ford Motorcraft oil. The vehicle takes about 6.5-7qts. to fill it up.
But you are free to use any oil you choose such as Mobil 1, Ams Oil, Royal Purple, Castrol, and Penzoil--synthetic, syn blend or conventional won't really matter as long as you stick to one type.
Old 06-18-2009, 10:17 AM   #4
I know some of the 03/04 cobras oil dip stick doesnt read right~ I would put what the factory recommends~ maybe .5 more quarts.
cam swap without removing the engine? ridelikehell Pre-2005 V6 Mustang 15 01-09-2004 07:42 AM
10:17 AM
