2000 Ford Mustang Replace radio speakers not working - Mustang Evolution
Old 06-26-2009, 09:39 AM   #1
Hi
I replace stock radio in my 2000 Mustang cd player below radio unit.
I installed a Alpine CDA-9883. I used a scosche fdk106 wiring harness.
Can someone resolve this problem. Thanks
tralfaz is offline   Reply With Quote
Old 06-26-2009, 10:03 AM   #2
Re: 2000 Ford Mustang Replace radio speakers not working
welcome :thumbs2:
I am not experienced in audio or wiring, but I'm sure someone here will be able to give ya a hand
Old 06-26-2009, 11:52 AM   #3
if you had the mach 460 system you have to fully remove it to get anything to work
Old 06-26-2009, 12:49 PM   #4
Hi,
I'm not sure if I have the mach 460 system, I had ford radio in top deck, it has
a 6 pin connector which went to the cd player down below, and an 8 pin connector which I connector to wire harness for speaker and it have a long 8 pin connector which I connect to power. I wire yellow to yellow, red to red, black to black, I didn't use the orange, orange white, or orange black. How do you remove mach 460 system?
Thanks For your help
Old 06-26-2009, 08:06 PM   #5
OsirisGuy's Avatar
So you replaced the bottom "radio" (actually just the CD Player)? That's what I am understanding. You also left the top radio (actual radio) in? If so, then the top radio has to be replaced, the bottom CD Player is just an "add on component" so to speak.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-27-2009, 08:01 AM   #6
No I removed both pieces. I just put the new radio in the top slot. I left the bottom slot
open for know.
Old 06-27-2009, 03:23 PM   #7
OsirisGuy's Avatar
If you had the CD Player in, then you should have the Premium sound system, meaning there is an amp. There should be two square plugs behind the Radio.
I think I know what you did.
You said you plugged in the 6-pin harness that goes to the CD Player? That bundle of wires is meaningless now, you can take that out. Behind the Radio the other square plug should be an 8-pin connector - those are your audio wires. Plug into that instead.
So you should have two harness plugged in. The long skinny gray rectangle and the square black harness.
OsirisGuy is right
2002 Mustang GT
Old 06-28-2009, 04:35 PM   #8
No I did use the 8 pin wire, still have no speakers.
Old 06-28-2009, 05:20 PM   #9
OsirisGuy's Avatar
How about the blue wires? Did you hook those up. It now sounds as if you're amp is not turning on.
OsirisGuy is right
2002 Mustang GT
Old 06-28-2009, 05:46 PM   #10
Hi
What do I hook the blue wires up too?
Thanks
Old 06-28-2009, 05:47 PM   #11
I have a blue and ablue white on the long 8 pin connector.
Old 06-28-2009, 05:48 PM   #12
I tried hook up the blue with the blue white. I still have no sound
Old 06-28-2009, 06:24 PM   #13
OsirisGuy's Avatar
On the harness for the aftermarket radio there should be a blue wire, you can hook both blue and blue/white up to behind the radio. If the radio has just a blue/white wire you can hook up the other harness blue and blue/white wire to the radio's blue/white wire. If the radio's harness has both a blue and blue/white wire then you can hook up each individual wire to it's respective one. Confused yet? Summary: Make sure the blue/white wire on the aftermarket harness going into the car is hooked up (has power).
If the radio harness does not have any blue wires you can tap the other harness' blue and blue/white wire onto the red wire.
Blue: Power Antenna
Blue/White: Amp Turn On
Red: Accessory
Yellow: Battery
Black: Ground
Oranges (grouped): Dimmer, dimmer ground, dash lights.
Speakers
White / White/Black: Drivers Front + / -
Gray / Gray/BLK: PF + / -
Green / Green/BLK: DR + / -
Purple / Purple/BLK: PR + / -
OsirisGuy is right
2002 Mustang GT
Old 06-29-2009, 07:42 AM   #14
Thanks You Radio works great. Thanks FOR ALL YOUR HELP
Old 06-29-2009, 04:05 PM   #15
OsirisGuy's Avatar
Glad to hear it's working, I don't know what I'd do with out music.
OsirisGuy is right
2002 Mustang GT
im about to replace my clutch/flywheel what else should i replace? 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:22 AM
2000 Ford Mustang Replace Radio No sound from speakers tralfaz Mustang Audio & Video 0 06-26-2009 03:24 PM
Power Windows Global Access NOT working after SJB replace - Is this fixable? HOW? bighank General Mustang Discussion 0 09-30-2008 05:26 PM
door speakers not working greenpony02 Mustang Audio & Video 1 05-26-2007 11:48 AM
12:29 PM
