New to site from the GA and need some help with my Mustang - Mustang Evolution
Old 08-14-2009, 01:27 PM   #1
Hey my name is anthony im new to the site i hope to make alot of new friends that are into there car as much as i am. Here is alittle about my car, ok i got this mustang about a week ago and here is what has been done to it before i got it. The body is a 1995 v6, the engine is a 98 4.6l gt and it has a procharger on it. As far as engine mods it has the pro charger a 75mm throttle body a 90mm SCT senors, Ford racing heads,12lbs pulley giving it 12lbs of boost, its runing on 32lbs injectors and it all so has the 2:55 fuel pump. It has the stock v6 suspension set up on it. the rear end is a 8:8 gt rear end. the guy i got it from had it dynoed and it put 425 hp to the wheels
Here are the ?'s i have. The mustang wants to keep dying on me when i come to a complete stop like at a red light. I dont know if i need bigger feul injectors or if it just needs to be tuned. I was thinking about changing to a 10lbs pulley and seeing if that would help. Then what kind of suspension should i put under it? And i dont know what gears to put in it i was thinking 4.10 gears if anyone can help me a really appreciate it thanks
1995procharged is offline   Reply With Quote
Old 08-14-2009, 04:47 PM   #2
upton7's Avatar
Re: New to site from the GA and need some help with my Mustang
As for gears i would go with 3.73. If i was pickin out new suspension i would go with eibach springs and bilstien shocks and struts. Then some mm subframe connectors. And mm caster camber if your lowering it.
Old 08-15-2009, 09:58 PM   #3
welcome :thumbs2:
I'd say upton's got ya covered
new mustang, new to site 07GT New Member Introductions & Greetings 10 10-07-2006 07:57 PM
Killer New Mustang Site..... Female_Entity The Bar 4 11-10-2004 11:24 PM
New Mustang Auction Site racinjason89 The Bar 12 08-16-2004 07:05 PM
What do you guys want from a V6 Mustang site? Brent The Bar 38 02-07-2004 02:25 PM
11:41 PM
