v6 mustang - Mustang Evolution
Old 10-27-2009, 08:35 PM   #1
v6 mustang
i have a 86 v6. i can not get it to start. i have replaced the fuel injectors and fuel pressure regulator, the only way i can get it to start is to spray starter fluid in it. once it was burned up it would cut off. it is not getting fuel in to the injectoer but i do have fuel up to the injectors. i turn the releace valve and fuel goes in. what am i missing?
black is offline   Reply With Quote
Old 10-28-2009, 07:14 AM   #2
Re: v6 mustang
you may have a hole in your fuel line (check the fuel pressure) my friend had a little hole in his fuel line right before the tank and it wouldnt hold suction to pull the fluid through the line.
Old 10-29-2009, 09:53 AM   #3
OsirisGuy's Avatar
Re: v6 mustang
Fuel lines, soy no con bueno.
But perhaps the ignition is not correctly wired? I could think of a few possible other reasons why.
What does the engine do when you go to crank it?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
v6 mustang
07:52 AM
