hi new guy needs ansewers? - Mustang Evolution
Old 10-08-2005, 07:10 PM   #1
Send a message via Yahoo to 95gt350
Question hi new guy needs ansewers?
i just bought a 88 stock 5.0 t top 5speed. i ran a 15.3 94 mph want to run 13s frist thing the car allways idle up n down dont know why? second thing is the mass air flow sensor do i need one or not and where do i get one and how to hook it up thrid and last the alt gauge needle goes up n down with the rpm is 75 amp want to put 95amp do i need to up date the wires if i do where do u get the up grade. thanx
95gt350 is offline   Reply With Quote
Old 10-08-2005, 07:14 PM   #2
Re: hi new guy needs ansewers?
Welcome...and I'm no good at 5.0's.. someone will come in in a minute and answer ya.
Old 10-09-2005, 04:05 PM   #3
do you have an aftermarket cam? The 5.0s are set in the cpu to idle at 650 rpms~ and the cam usually wont let them, thus the cpu is trying to compensate and you get the rpm jumping. If you have a stock cam I would try to clean your MAF wire, clean your air filter (or replace depending), clean your idle bypass valve (IAC) and make sure all of the electrical hook ups are good and connected right. Reset the battery lastly and see how it goes after driving it normaly for a few miles.
Old 10-09-2005, 10:29 PM   #4
Zim
You want to **** me?
Zim's Avatar
^^ I was going to say pretty much exactly what he did, so follow that advice
I like toys
Old 10-10-2005, 10:04 AM   #5
Tbird232ci's Avatar
as for the alternator, to upgrade to a 95 amp, you should at least run a new power wire over to the selenoid, run an 8 gauge wire in addition to the factory one, and all should be good
to run 13's, you will need the Mass Air conversion, there are differnet ways to convert, theres a 400 dollar kit, then there is a kit where you track down the computer for the Mass Air yourself, and it gives you the wiring harness to add the Mass Air using a meter your found yourself
Old 10-10-2005, 12:08 PM   #6
fast64's Avatar
if you decide to track down everything yourself, heres a list of computer codes so you know what you can use and what you can't: http://fordfuelinjection.com/?p=17
GO BRAVES
Old 10-10-2005, 04:18 PM   #7
thanx for your help guys im going to check on the maf and on the link u give me thanx to fast64. im going to clean the idle bypass valve like i said the car is all stock needs alot of tlc i just got from my buddy an off road pipe if you think of any more please tell me thanx again
Old 10-11-2005, 07:22 PM   #8
Tbird232ci's Avatar
right now, just get everything in proper running order
do you plugs (autolites preferably, NO PLATINUMS), some good quality spark plug wires, cap, rotor, fuel filter, change the oil, and anything else you could possibly think of
it wouldnt even hurt to crack open the tranny, and put fresh fluid in it (5-speed still have fluid), and drain the gear oil out of the rear and put fresh in with friction modifier
Old 10-12-2005, 10:56 AM   #9
V6STANG007's Avatar
Send a message via AIM to V6STANG007 Send a message via Yahoo to V6STANG007
welcome
Jorge ~
Originally Posted by Danger Dude
OK you are right!!! Maybe I am the Old Crazy One
V6STANG007 is offline   Reply With Quote
Old 10-13-2005, 02:37 PM   #10
ur bittn's Avatar
Welcome! I am new also, very cool site.
White 03 Cobra
Vinyl Shelby Stripes
Borla Stinger
K&N FIPK II
2.93 Pulley
Autologic chip
Swanson Tune
Eibach pro kit
Maido GR5, 20" x 10.5 back 20" x 9" front
WGW ajustable shifter & cobra knob
430 rwhp "with belt slip"
ur bittn is offline   Reply With Quote
Old 10-16-2005, 04:37 PM   #11
should i use brake cleaner on the idle bypass vavle
Old 10-17-2005, 08:57 AM   #12
Tbird232ci's Avatar
use carb cleaner, brake cleaner will eat at the o-rings in it
Old 10-20-2005, 04:55 PM   #13
Rick0636's Avatar
There is also special electronic spray cleaner which might even be better, I think Auto Zone stocks that. Only a few dollars.
Old 10-29-2005, 06:51 PM   #14
well i will be working on it all winter i just got cai and 3:73 gears to start me off to my goal. i will do the tips you guys gave me as a start thanx.
Just another new guy a_neg New Member Introductions & Greetings 8 08-03-2009 10:43 AM
New Guy johnm New Member Introductions & Greetings 8 03-12-2008 06:27 PM
The New Guy Mark New Member Introductions & Greetings 17 03-20-2007 08:35 AM
New Guy 12Pack New Member Introductions & Greetings 10 09-14-2005 12:21 PM
Hm...maybe this guy has something. lowflyn The Bar 15 09-12-2005 06:00 PM
06:30 AM
