HELP THE NEW GUY - Mustang Evolution
Old 02-22-2010, 02:18 PM   #1
HELP THE NEW GUY
ok guys heres the questions...i just bought a 2000 ford mustang gt..
the key wont disarm the alarm..if you use the key to open the door it wont disarm the alarm..have to use the remoteto disarm it so the key will start the ignition..if you use the remote to get in the car you still have to use the remote again once the key is in the switch to disarm the system...WTHell.. i am not familiar with the new car security system and home a fellow mustang brother has the answer..thanks
yerg is offline   Reply With Quote
Old 02-22-2010, 02:21 PM   #2
upton7's Avatar
Re: HELP THE NEW GUY
What?
Old 03-03-2010, 02:37 PM   #3
OsirisGuy's Avatar
Is it an aftermarket alarm system? What about the key, does the butt end have a big plastic base around it? Or is it all metal?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 03-03-2010, 07:27 PM   #4
big show 98's Avatar
big show 98 is offline   Reply With Quote
Old 03-03-2010, 07:32 PM   #5
Hm...is it the normal Ford keyfob? Sounds like an aftermarket alarm problem...
Old 03-04-2010, 08:04 AM   #6
ok update...been working on this lil 4.6 pony and have found out that the alarm arms itself after about 15-20 seconds..t is automatic and will do it on its own..is this normal? anyway just changed all of the fluids..had a tranny leak on the dipstick tube o ring..what a huge pain in the butt it was to remove it..do love the fact that the converter has a drain plug in it....so far about 500.00 dollars in parts.. i noticed that the rear end must have some tall gears..and the bearings in the right rear are making some noise..what next? good thing i love my ford
Old 03-04-2010, 08:24 AM   #7
that alarm is not factory, its aftermarket so we wont be be much help unless someone that knows what type of alarm or how to wire them replies. I dont know of any aftermarket alarm that turns off with a key~ you should be using the fob to unlock the car anyway I never use my key hold on my door lol, to much risk of scratching the paint.
Old 03-04-2010, 10:53 PM   #8
OsirisGuy's Avatar
Do you also have a remote start? What does the key fob look like?
OsirisGuy is right
2002 Mustang GT
new guy from MN redcobravert New Member Introductions & Greetings 17 08-17-2009 09:57 AM
Just another new guy a_neg New Member Introductions & Greetings 8 08-03-2009 11:43 AM
New Guy johnm New Member Introductions & Greetings 8 03-12-2008 07:27 PM
New Guy 12Pack New Member Introductions & Greetings 10 09-14-2005 01:21 PM
Hm...maybe this guy has something. lowflyn The Bar 15 09-12-2005 07:00 PM
10:19 AM
