1998 Mustang GT Best way to increase hp/performance? - Mustang Evolution
Old 04-22-2010, 11:48 AM   #1
All idea are welcome. Looking to increase performance at reasonable price. 3.73 gears are the best way, so I've heard. Any other ideas? Thanks!
JDmustang98' is offline   Reply With Quote
Old 04-22-2010, 02:51 PM   #2
Re: 1998 Mustang GT Best way to increase hp/performance?
gears add no hp or tq but since generally those cars have 2.73 rear gears stock 3.73 will make the car about half a second quicker 0-60 but gas mileage will suffer some.
The next best thing would probably be a PI head swap (99-04 GT heads) this will bump you up to around 285hp.
Old 04-22-2010, 03:09 PM   #3
67mustang97's Avatar
Region: Vermont
Why does doing the PI swap give you more hp than a car that came with the PI heads and intake? 260 - 285 is huge for us NA guys.
Old 04-22-2010, 03:47 PM   #4
the compression ratio is higher on that style with the swap than on the 99-04. or so i believe.
tigerfan2771 is offline   Reply With Quote
Old 04-22-2010, 03:48 PM   #5
but +1 on the pi swap if you can do it. gears are probably the second best mod for the money.
Old 04-22-2010, 07:07 PM   #6
welcome
Yah I'd agree and say the PI swap and gears will be your most effective mods.
If you're an auto a tune would really help your transmisssion.
Old 04-22-2010, 07:11 PM   #7
welcome
yea and you would need that anyway with either of those mods.
Old 04-23-2010, 09:57 AM   #8
racefan966's Avatar
Region: Idaho
What to do? Well gears won't add HP but will add better take off as for the gears to go with here is what I found. 3.73's are the tallest you want to go with a 5spd and 4.11's are the tallest to go with on an automatic. As for power adders there are many you do. You have Cold Air Intakes, larger throttle bodies and mass air flow meters. You can do headers and cat back with H-pipe. Then you have the power programmers and turbo's and pro chargers and so on. The list is almost endless. Keep in mind that if you improve the air intake you should do the exhaust to really get the gains. Hope this helps.
racefan966 is offline   Reply With Quote
1998 mustang
Best HP Increase with a $500 budget? v0nz Pre-2005 V6 Mustang 12 11-20-2009 02:28 PM
Want to Increase Gas Efficiency Osalcido Pre-2005 V6 Mustang 40 05-26-2006 03:55 PM
HP increase jimmy_beaner Pre-2005 V6 Mustang 25 08-15-2004 07:41 PM
Hp increase timpryor Pre-2005 V6 Mustang 4 07-12-2004 11:48 AM
03:03 AM
