Another for the Starkville/MSU Group - Mustang Evolution
Old 02-07-2007, 12:10 PM   #1
Y2E0L0L5OGWT's Avatar
Hey guys, I'm Chris from Starkville...If you can't tell, I have an 05 GT...All the guys in this area already know me, but it's yellow with black racing stripes and door stripes, borla cat-back, 18" deep-dish bullits in the back, and the louvers for the back glass. I will be putting a KB 2.6L on it hopefully by August, depending on funds...
Old 02-07-2007, 12:13 PM   #2
bluemustang's Avatar
Re: Another for the Starkville/MSU Group
Welcome to the board :approve:
Old 02-07-2007, 12:15 PM   #3
Herbstang's Avatar
Welcome To ME :smoke:
Old 02-07-2007, 12:27 PM   #4
Welcome to Mustang Evolution.
JROC is offline   Reply With Quote
Old 02-07-2007, 01:44 PM   #5
Welcome
Old 02-07-2007, 01:46 PM   #6
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Welcome to the Family....Never a dull moment around here
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 02-07-2007, 03:07 PM   #7
meteorachick's Avatar
oh man, the mississippians are multiplying! ahhhh!!!!
lol j/k...welcome to the site!
Modified 2004 V6
Old 02-07-2007, 03:11 PM   #8
Welcome to the site chris, now if we can just get the other ppl on here lol.
We're gonna have to make a starkville section here soon.
Old 02-07-2007, 03:29 PM   #9
Aidan_04's Avatar
*poke*
I know you.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 02-07-2007, 03:43 PM   #10
Welcome to the party!
Old 02-07-2007, 03:44 PM   #11
hey you should look at gettin a turbocharger for your mustang instead of the kenne bell I think you will be a lot happier and i can get you a good deal on install and parts with some of my buddies in Memphis...plus turbos are cheaper and less stress on the engine look at the Hellion site
volantus is offline   Reply With Quote
Old 02-07-2007, 04:32 PM   #12
bullitt482's Avatar
/\ Nothing like a welcome with advice.
Sup Chris... Wilcommen!
01 Bullitt
Old 02-07-2007, 04:51 PM   #13
Kiljosh's Avatar
OooOoOoooo KB 2.6
Welcome
Btw Id rather have a roots supercharger than a turbo...
Old 02-07-2007, 04:55 PM   #14
bullitt482's Avatar
Originally Posted by Kiljosh View Post
OooOoOoooo KB 2.6
Welcome
Ever touch a Kenne Bell or other roots blower after it makes a 1/4 mile pass? Granted a Turbo generates more heat, but it also allows for lower intake temps with a large intercooler.... Plus you have heat soak issues with a Roots blower.
Capabilities:
Turbo>Screwtype blower(kenne bell and Ford GT Eaton)>Roots(eaton off the termy's)
01 Bullitt
Old 02-07-2007, 04:57 PM   #15
Kiljosh's Avatar
Roots = best looking engine bay, awesome down low power, less chance of your car blowing up because of the simplicity of the system over a turbo imho.
Everyone likes their own thing...
Old 02-07-2007, 04:58 PM   #16
Kiljosh's Avatar
And when I say roots I was grouping Twin screw and single screws, just differentiating between the centrifugal and roots type.
Old 02-07-2007, 05:05 PM   #17
bullitt482's Avatar
I would let this argument go, but your reasoning befuddles me. A screw type is a kenne bell. Roots is what the stock termy's have. So you saying a stock blower looks better than a Kenne Bell/Whipple? And if you have the correct turbo with the correct tune, you can have the same power down low and even more up top. The whole idea of taking power to make power isn't that good of idea to me, but like you said to each his own. I just thought you should have better reasoning that that.
01 Bullitt
Old 02-07-2007, 05:08 PM   #18
bullitt482's Avatar
Roots and Screw types are two different classes of blower....
01 Bullitt
Old 02-07-2007, 05:11 PM   #19
Kiljosh's Avatar
Maybe I have been mis informed than.
I always thought a Roots type blower is one mounted directly to the lower intake of a car and makes boost in the intake not in the blower itself. Twin screw and single just simply being one more efficient way of making the same boost over the other?
Old 02-07-2007, 05:24 PM   #20
bullitt482's Avatar
Totally different designs on the inside....
"Roots
A Roots-style blower is probably the most commonly noticed supercharger at cruise-ins. On some applications these stick out of the hood with one or two carburetors attached. These units act as an air pump so that the compression of the inlet charge (boost) takes place inside of the manifold and cylinders, external from the blower. Because every full rotation of the Roots compressor element generates a specific amount of air pumped from the inlet side to the exhaust outlet (directly into the intake manifold), the Roots style is considered a positive-displacement blower.
Inside the case of a Roots blower are intermeshing, rotating rotors. A crankshaft-mounted pulley spins a drive pulley through a belt (typically cogged on larger blowers to eliminate slippage). The drive pulley, mounted on the front of the supercharger, is connected to internal gears that turn the rotors. The spinning of the rotors compresses air and fuel supplied from either the carburetor(s) or a fuel-injection system mounted above the blower case. This air/fuel mixture is pumped between the supercharger case and rotors.
Traditional Roots-style superchargers generally produce on-the-spot boost pressure down low in the rpm band and maintain it as engine speeds increase. However, efficiency generally tapers off at higher rpm due to heat buildup inside the case and leakage past the rotor seals. The added temperature may make the engine more prone to detonation. Two ways to counteract this problem are to run a slightly larger blower, which helps move more air, and underdriving the blower slightly to reduce boost.
Not all Roots-style superchargers operate with the same technology. Some are newer with hybrid designs, such as the Eaton or Magnuson models. These units use a high-helix set of involuted rotors that produce an axial airflow. In other words, they run the air movement from the back of the unit and discharge it at the front. This differs from the traditional Roots supercharger that pulls air in from the top and delivers it through the bottom. A Magnuson-style unit also incorporates a bypass or unloader valve that bleeds off air pressure at part-throttle operation, thus reducing mechanical losses.
Twin-Screw
The outward appearance of a twin-screw supercharger appears very similar to a traditional Roots-style unit, but there are a few distinct differences. A twin-screw's air compression takes place inside the supercharger, making it an internal-compression unit. Second, a screw-type blower uses rotors with tighter clearances that interleave to pull in and compress the air as it passes through. Third, the incoming air enters the twin-screw supercharger through the rear or top rear. The shorter airflow path of a twin-screw minimizes the high turbulence, friction, heat (reduced often by 50 percent), and pumping losses commonly found with the traditional Roots designs. Like all superchargers, the twin-screw is beltdriven. Because of the closer tolerance design, a twin-screw supercharger is often more expensive than a standard Roots type."
All The Basics Of Engine Superchargers - Chevy High Performance Magazine
The Eaton's on the Cobra's are newer versions of the traditional roots blowers, causing confusion. I see where you are coming from. When I think roots, I think 8-71's on the Alcohol cars.
01 Bullitt
Old 02-07-2007, 08:10 PM   #21
Kiljosh's Avatar
Thanks I see now, it may look the same on the outside but actually very different.
Wow this was a major thread hijack. Sorry!
Old 02-08-2007, 02:46 PM   #22
bullitt482's Avatar
Yep, sorry bout that TJ'in....
01 Bullitt
Old 02-08-2007, 05:15 PM   #23
rydog's Avatar
Send a message via MSN to rydog
Welcome:wave2:
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 02-10-2007, 02:48 PM   #24
rocknbronco's Avatar
Howdy
rocknbronco is offline   Reply With Quote
Old 02-10-2007, 05:37 PM   #25
Taywi's Avatar
Send a message via AIM to Taywi
Welcome to the EVOLUTION...
from old and busted to new hotness
Taywi is offline   Reply With Quote
Yet another starkville guy... A5295 New Member Introductions & Greetings 23 02-28-2007 06:53 AM
noob from memphis/starkville volantus New Member Introductions & Greetings 54 02-13-2007 11:09 PM
Looking for FF XI Group Extreme Effects.com The Bar 0 07-02-2004 05:12 PM
MSU at Arkansas lowflyn Regional Mustang Discussion 0 11-20-2003 10:25 PM
Joining the group here 2000blackone The Bar 13 09-08-2003 09:31 PM
10:22 AM
