Convertible top problems - Mustang Evolution
Old 09-01-2010, 06:50 AM   #1
Unhappy Convertible top problems
I have a 1988 Mustang GT Convertible with a problem. The top will not go up. The motor is not making any sounds. I checked the fuses under the dash. Can anyone help??? I don't want the call the mechanic for something small.
mlbergeron is offline   Reply With Quote
Old 09-01-2010, 07:51 AM   #2
Re: Convertible top problems
I would take the back seat out Not sure how to in your year car
Then you can see the top motor, check for leaks of fluid, if all that is good use a power tester (screw driver thing with a wire to ground) to see if the motor is getting power when you push the button.
If the power tester shows the wire has power but the top aint moving either you dont have fluid, the top motor is burnt up, or something along those lines. Listen to the motor. You can also wiggle the connections etc to ensure a good contact (clean the contact wires as well)
YOu can disconnect the motor from the top and put it up manually if you have to~
Old 09-01-2010, 09:27 AM   #3
Smile Re: Convertible top problems
Thank you... I will try it.
convertible top pipeguy 1996-2004 Mustang GT 13 07-26-2008 08:36 AM
Convertible top Scarlet General Mustang Discussion 3 06-05-2008 10:34 PM
04:10 PM
