Head gasket - Mustang Evolution
Old 01-03-2011, 02:56 PM   #1
Head gasket
I have a 01 cobra and blew a head gasket what all has to be done besides replace the gasket I was having a lot of water in my exhaust car was running rough and loss of power
Sick01cobra is offline   Reply With Quote
Old 01-03-2011, 07:33 PM   #2
Re: Head gasket
Just about every gasket from heads up needs to be changed and the head may be cracked or worped. Its not and easy job changing head gaskets on a 4.6L because of the cams and all the electronic stuff.
Straublittleman is offline   Reply With Quote
Old 01-03-2011, 09:17 PM   #3
Yup, that's another reason I like my pushrod 5.0!
If it was me I would change them both out while I had it apart, and yes, you need all the gaskets from there up. OHC engines are not that fun!
93CobraGuy is offline   Reply With Quote
Old 01-05-2011, 02:10 PM   #4
There is a place called B&R hear in Oklahoma about the best place 4 stangs so I have herd they said about 1800 to 2000 to fix it and that includes labor and parts and getting the heads re-surfaced and valve job does this sound like a normal price ? And around 600 to re do the rear end with 3.73s .
Old 01-05-2011, 03:45 PM   #5
Re: Head gasket
600 to redo the rear end is ok if it includes gears and rebuilding the tlok. normal installation for a set of rear end gears should be 300 give or take a little.
Head Gasket ?s 95-3.8 cgff Pre-2005 V6 Mustang 4 01-27-2010 08:17 PM
head gasket replacement on 04 GT mikeg 1996-2004 Mustang GT 6 12-03-2009 08:56 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
02:56 AM
