spark plug mix up - Mustang Evolution
Old 02-06-2011, 04:05 AM   #1
97stangOn22z's Avatar
Region: Arkansas
spark plug mix up
hey guys. i did a tune up and now my mustang has the shakes!!! and a lost of horse power. im thinking i got my plugs mixed up. can anyone with a v6 3.8 mustang go and look at their spark plugs directions and let me know which way mines should be going from the coil pack to the engine. PLEASSSSSE HELP. nothing more irritating than a mustang with no horse power!!!!!
97stangOn22z is offline   Reply With Quote
Old 02-06-2011, 04:11 AM   #2
Re: spark plug mix up
Let me find a diagram for you, give me just a minute!
93CobraGuy is offline   Reply With Quote
Old 02-06-2011, 04:13 AM   #3
Region: Arkansas
thanks.
Old 02-06-2011, 04:15 AM   #4
This is for everything....
Old 02-06-2011, 04:18 AM   #5
Region: Arkansas
COOL!!! oh i wrote you back. your A-ok with me man.
Old 02-06-2011, 07:58 AM   #6
Wolfsbain76's Avatar
Ummm...do the newer vehicles need this? Or do they have the computers on the vehicle to do it for you? Take my "07" for example. I'd like to try my first tune up on my own and I wouldn't want to screw it up. Will I need to look at the diagram for my 07?
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 02-06-2011, 10:17 AM   #7
stampde's Avatar
Just do one plug at a time , remove the coil pack, change plug , re install coil pack , move on to the next one , etc ........ EASY
2011 GT Auto
Old 02-06-2011, 11:28 AM   #8
Titus Wadicus
svtlx's Avatar
im pretty sure he will from this point on...lol.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-06-2011, 12:36 PM   #9
Sweet! many thanks!
Moving on is so hard to do!
2007 Mustang GT
Old 02-06-2011, 02:42 PM   #10
Titus Wadicus
svtlx's Avatar
Sweet! many thanks!
Blew a spark plug Mustangfan2003 1996-2004 Mustang GT 3 09-18-2009 12:16 PM
Spark Plug 1234 The Bar 9 08-07-2008 10:23 PM
spark plug ? foxbodym 1979-1995 Mustang GT 5 07-17-2008 06:02 PM
Spark plug test 98StangGT 1996-2004 Mustang GT 2 09-19-2006 04:49 PM
spark plug gap mustangruss Pre-2005 V6 Mustang 3 12-23-2005 04:37 PM
08:02 PM
