New member with electrical & idle problems - Mustang Evolution
Old 01-17-2012, 10:38 AM   #1
Region: Arkansas
Have a 2001 mustang v6 convertible. My cig lighter plug fuse keeps blowing for no reason & think it's the culprit in my battery drain issue. If I don't drive it for a day or 2 the battery is completely dead & I have to jump it to get it started again. There's absolutely nothing else that could be running the battery down. I don't have any aftermarket electronics in the car at all. When I change the fuse its blown in a day or two. I guess it's a short somewhere. Does anyone know a fix for this ?? Also it idles at like 1900 rpm's when I start it & sometimes after I stop after its warmed up. Not sure what to do about that either & sometimes it idles too low when I start it like at 600 rpm's maybe. Any ideas on this ??
Kevin8677 is offline   Reply With Quote
Old 01-17-2012, 07:53 PM   #2
Hey kev.welcome to ME! I would worry about the short first.what I would do is get a Haynes or Chilton with a wiring schematic to help in chasing down the faulty wire/wires.try unplugging what u think the problem is and see if the problem continues.if it does then the part maybe faulty.
Just so u know u may have better results posting in the proper v6 section.those guy may know of common problems,recalls etc.
Hope you like the site and good luck!
1987 Mustang GT 5.0: Huge Help Needed Johnson 1979-1995 Mustang GT 24 01-18-2012 08:19 PM
Idle problems BigB227 1996-2004 Mustang GT 5 12-06-2011 10:57 PM
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 08:44 PM
Idle problems need some help stangrunner 1979-1995 Mustang GT 6 09-16-2011 07:49 PM
Y2k v6 idle problems 6Banger2000 2005-2010 V6 Mustang 4 07-22-2011 07:10 AM
11:37 PM
