Hello again - Mustang Evolution
Old 05-13-2012, 07:21 PM   #1
Hello again
Stoped by to say hi and give a little up date on project sn95. Orderded bbk equil length tuned headers bbk 75 mm throtle body bbk underdrive pullies and sct tunner chip for 93 octain also installed 3.73 rear ring and pinion gear all new seals bushings barrings ext went with 2 quarts of royal purp gear oil ac is comming off very soon and smog pump delete is on the way allready installed is the rear gear k&n ram air kit accu-drive timming gears msd distributor 8.8mm plug wires and blaster coil as well as stage one shift kit for aode trans 3in exhaust with side pipes cats are long gone and the 427 windsor is still being built but i wanted to do a little racing this year so the majority of the parts i got for the 302 i can use on the 351 so no waisted $$ will post time slips when i have some. Keep tunning stang heads!
Hawk is offline   Reply With Quote
03:11 PM
