4.6 npi block with pi heads - Mustang Evolution
Old 07-06-2012, 12:22 PM   #1
Rexxx73's Avatar
If anyone has tried to find if this will work the answer is yes. And not only that I used a Romeo block from crown vic po int car and my Windsor top end. Did the swap due to bad rod bearing. All I needed other the gasket kit was Romeo 6 bolt pattern flywheel since Windsor block had 8 bolt crank pattern
Rexxx73 is offline   Reply With Quote
10:27 AM
