Newby at this - Mustang Evolution
Old 11-16-2013, 08:10 PM   #1
Newby at this
I found this forum through surfing the web trying to find a solution to my mustang issue.
nobleone is offline   Reply With Quote
Old 11-16-2013, 08:11 PM   #2
MidnightBlueGT's Avatar
Welcome. Whats your issue?
Old 11-16-2013, 09:27 PM   #3
temp gauge
I own a 1995 Mustang GT. I started having an issue with my engine coolant temperature gauge pegging out past the 'H' and the gas needle going from F to E. It was clearly not running hot, I had the A/C on but shut it off once I saw the temp needle pegged out. My radiator apparantly had a small leak that was undetected until driving to work in heavy stop and go traffic in the heat of the day. Once I saw the steam from the driviers side of the engine I immediately pulled over and that is when I discovered the radiator was blown. I have since replace the radiator with an aluminum radiator, thermostat, Blue high temp hoses, fresh coolant and Hy-Per Lube Super Coolant. I have removed all of the air from the system and checked the engine block temp and radiator temp, none of which indicate a high temp as to where the temp needle reads. In fact after changing everything out. The needle pegged out when I crancked the car up a second time after pressuring out any air through the screw type vent on the thermostat housing. I also changed out the ECT on the lower intake. Any help as to how to solve this issue would be greatly appreciated.
Old 11-16-2013, 09:28 PM   #4
Old 11-17-2013, 10:15 AM   #5
tonyd01gt's Avatar
Welcome.
tonyd01gt is offline   Reply With Quote
Old 11-18-2013, 11:24 AM   #6
Iggy's Avatar
Welcome
Iggy is offline   Reply With Quote
Old 11-18-2013, 05:38 PM   #7
It's not me, it's you.
primer2tone's Avatar
Welcome!
Old 11-18-2013, 07:03 PM   #8
Hmiller's Avatar
Send a message via AIM to Hmiller
Welcome!
VOTE For MOTM!!!!!!
Hmiller is offline   Reply With Quote
Old 11-19-2013, 02:15 PM   #9
Devildogstang's Avatar
Welcome
Devildogstang is offline   Reply With Quote
Old 11-19-2013, 07:26 PM   #10
mustangchassy's Avatar
Welcome.
2013 GT Premium: 15% Tint/Roush Axleback/Gloss Black 5.0 Badges/2007 GT Premium (SOLD)
mustangchassy is offline   Reply With Quote
04:13 PM
