What to expect from these modifications - Mustang Evolution
Old 11-02-2014, 08:38 PM   #1
I have a 1999 mustang manual v6, I have searched around for the mods that best suit my plans (staying around factory mpg, but adding power output). As a goal I would like to give the same year stock v8 a run for its money, what do you expect as 1/4 mile time (stock is 15.9ish)? No specified companies due to indecision of what I want. Thank you in advance. And here is the list:
Cold air intake (possible windstar switch)
Under-drive pulley
Subframe connectors
8.8 end, 3.73 gears
Traction lock 8.8
Throttle-body
Coil pack
Tuner
Maybe's:
Aluminum driveshaft/flywheel
Turbo (if I save up enough)
4.3 liter conversion (if I save)
SimpleSixer is offline   Reply With Quote
Old 11-02-2014, 08:44 PM   #2
Forgot to add a mod, dual glasspack cat-back
Old 11-02-2014, 08:55 PM   #3
Unless you use nitrous,turbo, or supercharger you will need to build that 4.3 stroker to run with the 4.6. A good starting point would be upgrade the 7.5 or find an 8.8 and install 3.73 (ford gears) tuner of choice, mac long tube headers with matching h-pipe and 40 series flowmasters. This will give you a decent running car while you save up for future power adders.
Bigshow14 is offline   Reply With Quote
Are these good time for my modifications? Speed_Mister 1996-2004 Mustang GT 2 06-24-2012 11:27 PM
SO you expect to start your car up... PureVenom Pictures and Videos 17 01-31-2007 02:31 PM
what should I expect to pay for a decent.. MonteCitan Mustang Audio & Video 9 09-04-2006 12:23 PM
what to expect? a00v6stang Pre-2005 V6 Mustang 6 02-15-2006 12:18 PM
04:50 AM
