Mustang GT 2014 differential oil leakage - Mustang Evolution
Old 02-19-2015, 03:52 PM   #1
Aamirbaloch's Avatar
Hi there guys I have just found out that my GT 2014 leaking differential oils and when am driving it there is some weird sound like tick tick any suggestion if it is dangerous to drive it ?
Aamirbaloch is offline   Reply With Quote
Old 02-19-2015, 03:57 PM   #2
Leaking in the front or back of the differential?
Adventure till you drop
Old 02-19-2015, 03:59 PM   #3
From the back of the differential
Old 02-19-2015, 04:02 PM   #4
It's probably the rear seal, how much fluid is still in the differential?
Old 02-19-2015, 04:07 PM   #5
I couldn't check by my self but since last 2 days I was noticing a tick tick sound from the car, and I wanted to take it to the garage as it was late night in dubai and tomorrow it's Friday and all the garages are closed, so am kinda worried what I should do for now.
Old 02-19-2015, 04:09 PM   #6
Park it, and when the shops open up take it straight there.
Old 02-19-2015, 04:10 PM   #7
I was thinking to do that but at the moment am somewhere stuck around 70 km away from home would it be good idea to drive it home and park it or should I just leave it where it is ?
Old 02-19-2015, 04:13 PM   #8
There's a possibility that if you drive it that you could seriously damage the differential. You can drive it just make sure it has enough differential fluid...
Old 02-19-2015, 04:14 PM   #9
Any idea how I can check the differential fluids?
Old 02-19-2015, 04:15 PM   #10
Sorry just re read op give me one sec...
Old 02-19-2015, 04:16 PM   #11
2014 GT v8
Old 02-19-2015, 04:19 PM   #12
natestang07's Avatar
If it is anything like my differential there is a fill plug on the front side of the differential that you pull off and I believe they are supposed to basically full
Old 02-19-2015, 04:21 PM   #13
Alright, I tried to find were the plug is but no accurate pics. Usually in the front of the differential there's a metal plug towards the top. If you can get it open and stick your finger in there, and if there's fluid it's ok. But if there isn't, get some and put it in...
Old 02-19-2015, 04:29 PM   #14
Hmmmm let me try that, but how about the sound, ( tick tick ) if there are Atleast some fluid and sound is it gonna b fine ?
Old 02-19-2015, 04:30 PM   #15
Main concern is getting home to park it until you can take it to a shop...
Old 02-19-2015, 04:33 PM   #16
Yea exactly mate this is the first time this car had put me in a critical situation can't believe.
Old 02-19-2015, 04:34 PM   #17
If you can locate a parts store, they can help you check the fluid...
Differential leakage ? alecas447 1996-2004 Mustang GT 40 01-15-2015 09:11 PM
Minor rear end axle tube leakage? 2014oxstang 2011-2014 Mustang GT 17 11-22-2014 06:28 PM
Pinion Leakage on 2013 ginaxel123 2011-2014 V6 Mustang 21 05-01-2014 02:09 PM
2004 ford mustang v6 differential oil crazybox1918 Pre-2005 V6 Mustang 2 03-13-2014 07:55 PM
O no, Gas Tank Leakage Kiljosh Pre-2005 V6 Mustang 9 10-29-2004 08:22 PM
01:09 PM
