new member from texas - Mustang Evolution
Old 08-10-2008, 04:20 PM   #1
hows it going? i am in the process of buying my dads 1997 mustang gt convertable from him. ive been real big into modifying 4 cylinders and this would be the first v8 i had. only thing is it doesnt seem to have much power for my taste. what mods would you recommend to wake up some of the power hidden?
Madmark is offline   Reply With Quote
Old 08-10-2008, 04:41 PM   #2
Re: new member from texas
Welcome to the site!
Old 08-11-2008, 07:14 AM   #3
Herbstang's Avatar
Welcome To M.E. :smoke:
Old 08-11-2008, 07:16 AM   #4
the 96-98 mustang GTs are horribly slow and low on power~ thankfully they are cheap to boost up. The stock numbers are 215/285~
Most with those year GT's swap over to the PI setup (aka the changes they did in 99 to boost the power to 260/300) this mainly includes the new revised heads/cams.
When all is said and done you will be around 285/3XX due to if you install it on your year 4.6 the compression ratio will go up some.
Thats probably one of the cheaper ways to boost power as you can get an entire engine for dirt cheap to swap over the parts you need from.
You can build the engine up if you wanted as well~ some have pushed 450 out of a N/A 4.6
Old 08-11-2008, 12:05 PM   #5
1234's Avatar
Welcome
Old 08-11-2008, 12:27 PM   #6
thats pretty good to know, but what if im shooting for say 300-350 rwhp what would be the best mod set up? i am not mechanically incline so i can end up doing anything to the motor, just where to start gets me.
Old 08-11-2008, 06:29 PM   #7
i talked to good mech. he said that to buy a new motor the old 4.6 was a modular motor throw away when wore out he said any alterations would warp the block
bigbowl is offline   Reply With Quote
Old 08-11-2008, 06:30 PM   #8
i would like to know about cams for my 96 gt it is sick
Old 08-11-2008, 07:03 PM   #9
1234's Avatar
Then hes not that good of a mechanic
Old 08-11-2008, 07:39 PM   #10
then tell me about rebuild on 4.6 about installing cams about bigger heads
Old 08-11-2008, 07:44 PM   #11
1234's Avatar
What do you want the car to do when its done?
As in final hp.
Old 08-12-2008, 07:17 AM   #12
without really putting some cash into the engine you wont see 350rwhp/tq without a power adder~
Old 08-12-2008, 11:13 AM   #13
money is not that big of deal like heads and cam no one will tell me about cams
Old 08-12-2008, 11:27 AM   #14
dont worry about cams until you do if you do a head swap. You can stick money elsewhere and get better gains.I would start by adding a tuner,gears, exhaust, then go straight to a supercharger and a good custom tune.The pi head swap is a great upgrade and like mentioned before, you will raise your compression ratio a bit. The price will vary from 800 to 2000 on the pi head swap depending on what kind of deals you find on the parts. Comp cams makes some really nice cams (as do others) for the 4.6 and complimented with a set of degree gears you can see huge gains from them.
Benjytps is offline   Reply With Quote
Old 08-12-2008, 05:36 PM   #15
Welcome fellow texan, go cowboys
06v6stang is offline   Reply With Quote
Old 08-13-2008, 07:18 AM   #16
at7311's Avatar
Send a message via AIM to at7311
Welcome.
Go Cowboys!
at7311 is offline   Reply With Quote
Old 08-13-2008, 08:14 AM   #17
DarkShadows's Avatar
the best way would be to buy my buddies 97 supercharged gt
welcome by the way
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 08-13-2008, 03:46 PM   #18
< done the pi swap.
96 GT- Who knows what's in it.
Old 08-15-2008, 03:31 PM   #19
did not get what
texas
New from Texas jch_1120 New Member Introductions & Greetings 7 03-31-2010 01:29 PM
TEXAS upton7 The Bar 10 01-10-2010 01:18 AM
New member from texas!! will_0828 New Member Introductions & Greetings 13 12-15-2009 07:09 AM
New member from texas orion445 New Member Introductions & Greetings 17 12-14-2009 08:43 PM
Texas ERICK Regional Mustang Discussion 6 06-04-2009 03:29 PM
06:54 AM
