I will sell it for less than 20,000 just send me an offer.This is a one of a kind 97 mustang gt, very fast. When I built this car I did not care how much it would cost me as long as it was a head turner, fast and fun to drive. It breaks my heart to sell it. I love this car but I need to buy a house and start planning for the future.
TOO SEE MORE PICS CLICK OR COPY AND PASTE THIS SITE
Ford Mustang GT - 1997 Ford Mustang GT
ENGINE:
(Fox Lake Racing 4.6L Engine)
-Iron romeo block
-ARP studs in mains
-Stock strock steel crank
-Manley H-beam rods
-C-P pistons
-8 to 1 compression
-FM bearings
-File fit rings
-Fully balanced
-New timing chains , gears and tensioners
-ARP head studs
-Stage 2 ported heads
-Manley springs
-Ferrea valves
-226/540 custom cams 113 lobe center
-H-V oil pump W/billet gears
-7 quart oil pan
-P-51 aluminum valve covers
(Kenne Bell 2.2L Polished Supercharger)
-8 rib pulley kit
-Anderson Ford power pipe
-Pro M 92mm Mass Air Meter
-7.5 inch crank pulley for 20 psi
TRANSMISSON/DRIVELINE:
(Tremek TKO-600) 2.87/.64 gear ratio
-SPEC stage 3+ dual metalic clutch
-Mcleod steel bell housing
-Ford racing steel flywheel
-Ford racing aluminum drive shaft
-Ford racing 31 spline limited slip differential
-Moser 31 spline axels with 3" studs
FUEL SYSTEM: return style
-Weldon 2015 fuel pump
-CPR fuel rails
-65lb High Impedence injectors
-Weldon fuel regulator
-40 and 10 micron filters
SUSPENSION AND BRAKES:
-Tokiko HP struts
-Eibach pro kit springs
-UPR pro rear control arms
-UPR shark caster-camber plates
-Hawk brake pads
-Power slot rotors
-Subframe connectors
BODY:
-Saleen body kit
-Custom ghost flames
-Black with blue pearl paint
WHEELS AND TIRES:
-Chrome Cobra R
-17x10.5 rear
-17x9 front
-Mickey Thompson ET street drag radials
INTERIOR:
-Corbeau VX 2000 racing seats
-Auto meter tri pod
-New black carpet
-White face gauges
-Cobra mats
-Infinity Speakers
-AVN1 Navigation indash system
-Auto Meter Phatom gauges
(1)boost
(2)fuel
(3)Water temp
(4)Oil pressure
(5)5 inch tach with shift light
