1993 LX Mustang Coupe - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustangs for Sale and Wanted
Old 02-12-2008, 11:38 PM   #1
bullitt482's Avatar
Well, time to give it up for a while. We are in the process of looking into a house. Car is as follows:
1993 Mustang(about 89K on the body) with 91 motor(had 45K when installed, which would put it at around 55K or so now since i've put about 10 k on the car since i've had it).
Trickflow Track Heat kit(.499/.510 with 221/225 duration at .050 cam, Trickflow upper and lower intake, double roller timing chain, TF roller rockers, pushrods, heads, and everything else that I may have missed in the kit)
BBK unequal length shorties
BBK off road x pipe
Magnaflow "race" mufflers(the straight through ones)
Auburn differential
FRPP aluminum driveshaft
Ford Super duty "Z" tranny with 2.95 first gear
3.73 gears
King Cobra clutch
24 lb inj
Granatelli Mass Air (what I had at the time to make the car run right)
BBK 70 mm throttle body
NGK plugs
MSD Blaster coil
Lakewood 70/30's and 50/50's
Eibach drag launch springs (Don't think the bags hold air)
Underdrive pulleys(on there when we got the car)
Knock off 4 lug pro stars with MT ET Street DR's, they are at the wear mark 275/50 15's
Still has the clutch fan on it.
Heater and A/C still work.
5 inch autometer tack with tach light
Autometer oil pressure mechanical gauge.
Prothane urethane motor mounts
Southside upper and lower control arms
Now the cons:
Temp gauge just went to poo and still reads but instead of normal being at the middle like it should, normal operating temp is at the cold mark. I just bought an Autometer temp gauge and am awaiting a bracket to mount it. It's not installed yet. It has an exhaust leak on the driver side header. My fault due to my weak tightening of the header bolts so the gasket cracked off a little, minor fix. The car does need a tune and I have it running pretty rich right now. A check engine light showed up not to long ago and I'm 99 percent sure that it is just an 02 sensor that needs replacing since the car has been running rich, minor fix. I have removed the back seat and the spare to pull weight out of the trunk. Since it has the Drag Launch springs on it the left spring is not as stiff as the right and since the offset is not what it should be on the rims, the left side will scrub with weight in the rear.
Pics: (will try to get more up later)
Mustang Evolution - bullitt482's Album: stuff - Picture
$6500 or best offer
That means the price is negotiable people!
01 Bullitt
Old 02-14-2008, 06:31 PM   #2
bullitt482's Avatar
Re: 1993 LX Mustang Coupe
Wow, no replies yet? Wonder if someone hasn't started a rumor that it's "ragged out" or something like that. Same thing happened when I tried to sell the bullitt a while back, but it's still ticking 30 thousand miles later with just a clutch change.....
Sorry to digress, but someone has to know someone that's interested... maybe... possibly...
01 Bullitt
Old 02-14-2008, 06:42 PM   #3
Too much of a race car for me. I need a daily driver.
Old 02-18-2008, 12:37 PM   #4
bullitt482's Avatar
YAAAAAAAAAAAAAAAARRRRRR....
6,000 OBO this car needs to go before we get a house....
01 Bullitt
Old 02-19-2008, 07:02 PM   #5
bullitt482's Avatar
now considering trades...preferably a reliable DD
01 Bullitt
Old 02-20-2008, 07:17 AM   #6
Take that truck he's offering on TA
Old 02-20-2008, 08:15 AM   #7
MonteCitan's Avatar
I'll trade you my black on black hatch for your white notch :drool:
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-20-2008, 11:41 AM   #8
bullitt482's Avatar
we're considering it, but it's got a lot of miles
01 Bullitt
Old 02-20-2008, 11:45 AM   #9
Ah ok...well I'm keepin my ears open for ya man...
...I've got an 87 ranger sitting in starkville I'll trade...needs minor engine/transmission/body/fuel system work...
Old 02-20-2008, 04:11 PM   #10
bullitt482's Avatar
haha...I think we're gonna have to pass this time
01 Bullitt
Old 02-21-2008, 08:38 AM   #11
i have an 02 V6 that i could trade you if your interested
brando16 is offline   Reply With Quote
Old 02-21-2008, 02:13 PM   #12
bullitt482's Avatar
PM sent
01 Bullitt
Old 02-21-2008, 05:16 PM   #13
bullitt482's Avatar
sold
01 Bullitt
Old 02-21-2008, 06:45 PM   #14
MonteCitan's Avatar
Originally Posted by bullitt482 View Post
sold
that was fast
1993 5.0 coupe f/s mpsstang Mustang Parts for Sale and Wanted 1 01-23-2006 01:59 PM
04:46 PM
