Wanted: Wanted, help with install in miami - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustangs for Sale and Wanted
Old 11-25-2012, 01:14 PM   #1
Looking for someone in near the miami area that can install springs, shocks/struts and strut mounts. I'll pay you $150, I'll help with the install, and I'll let you keep my brembo springs, shocks and struts from my 13 gt. let me know!
Mikeyt03 is offline   Reply With Quote
Old 11-25-2012, 07:44 PM   #2
Rosco's Avatar
I will if your willing to fly me out there
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 12-15-2012, 11:27 PM   #3
1996mustang's Avatar
Im in the miami area imma look at alldata later on today to see the difficulty (if any) and i should be easily able to help u knock them out. Ill let u know soon as i wake up
Old 12-20-2012, 07:00 AM   #4
dgrum04's Avatar
Impressive sir. Sleep foruming, you're good..
2011 Kona Blue 3.7L. Stock motor. Roush Axle-Back. 19" x 8.5/10" Charcoal AMR's. GT500 Spoiler. Smoked Raxiom Tail Lights. MCA grille. Shorty antenna.
An outstanding DD
dgrum04 is offline   Reply With Quote
Old 12-20-2012, 11:00 AM   #5
I helped a friend on his 08 GT, was rather easy overall, not much two it but a friend does go along way in speeding it up
Old 01-05-2013, 08:04 AM   #6
rebeltx's Avatar
Did you get this done? There are enough build books floating around that you should be able to find a step by step guide....... Ford mechanics dont just magically know how to work on the new cars, There using the Ford build manuals like the rest of us are (if you can get your hands on them). Call an Autozone or some place like that and talk to someone about getting your hands on a build book for your GT. It wont be the one ford has but it will serve the same purpose, the one I had covered everything from oil changes to how to remove the a motor and trans to replacing a window and everything in-between. If you have the tools, time, and patience you can do just about anything yourself.
rebeltx is offline   Reply With Quote
09:08 PM
