For Sale: 2011 TWIN TURBO 3.7 - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustangs for Sale and Wanted
Old 05-04-2015, 07:12 PM   #1
JCALD's Avatar
2011 TWIN TURBO 3.7
I am selling my 2011 Twin Turbo 3.7 V6 Mustang. The following list covers most of the work done on the car. It has 58,600 miles with no collisions and no mechanical problems.
Asking $22,500
Invested over $34,000
Ford Racing Suspension Package (shocks, struts, springs, sway bars front and rear) Package lowered car approximately 2 inches.
2010 GT 500 18"x10" wheels wrapped in Nitto 555 tires (less than 4,000 miles on tires.
Brembo brake package.
New electronic rack and pinion steering unit. (replaced due to oil leak)
Brake cooling system which includes custom fabricated aluminum windshield washer tank to make room for the ducting.
PLX Device Gauges in Boss 302 gauge pod (AFR both banks, intake air temp, oil temp, water temp, boost/vacuum)
Barton Shifter on six speed standard transmission
Aluminum one piece drive shaft
3.55 Gears and Torsen R differential (transfers 4 times the torque to the wheel that has the most load in a corner)
Aluminum Ford Racing differential cover
Aerocharger variable vein turbos (absolutely no turbo lag)
Bell custom intercooler
Tial 50 MM Blow off valves
K&N air filters
KB Boost a pump
85 pound ID injectors
Pype Bomb axle back exhaust
SCT Tuner with current tune done by True Street Performance in McKinney, TX
Last tune netted 388 HP at 5,500 rpm and 450 FP of torque at 3,200 rmp to the wheels running 7.5 pounds of boost. More power on tap if you are willing to take the risk.
No check engine error codes.
V6 insurance for a performance car.
Check out my post under "3.7 Twin Turbo Build". I want to sell it as is so parting out is not a consideration at this time.
Drop me a personal message if interested.
Thanks
ID:	181846   Click image for larger version
ID:	181850   Click image for larger version
ID:	181852   Click image for larger version
Name:	IMG_3689 - Version 2.jpg
ID:	181856   Click image for larger version
Name:	IMG_3690 - Version 2.jpg
JCALD is offline   Reply With Quote
Twin screw supercharger pro charger or single/twin turbo? bryn 2005-2010 Mustang GT 2 11-19-2016 10:11 AM
Twin screw v.s. Twin Turbo?? Mad_blackmusty 1996-2004 Mustang GT 11 11-19-2016 08:29 AM
TWIN TURBO 2011 3.7 :: 2011 Ford 3.7 V6 JCALD Member Garages 2 01-12-2015 10:52 AM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
804 WHP Twin T57 03 Cobra vs 922 WHP Twin T60-01 SS JROC Pictures and Videos 27 08-31-2007 04:22 PM
05:21 PM
