60mm TB from 99-04 - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 11-05-2004, 10:12 AM   #1
97Stallion's Avatar
60mm TB from 99-04
For my project RDX intake, I think I'm going to need a stock TB from a 99-04. Let me know if any of you have one.
Living one day at a time!
Old 11-10-2004, 08:16 PM   #2
BlueDonkey's Avatar
I may have one; lemme root around the garage tomorrow.
edit, add: off a 99
BlueDonkey is offline   Reply With Quote
Old 03-05-2005, 06:01 AM   #3
RGR
Send a message via AIM to RGR
I got a 65mm one, from a truck, same bolt pattern.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-05-2005, 10:22 PM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Me too.
4.2 split port engine parts/torque converter/steeda parts
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-30-2005, 07:48 PM   #5
If your still looking for a stock t-body, I have one. I have a 2004 mustang V6 and changed it with a BBK 70mm t-body. PM me if you are still looking for one.
charlie6n is offline   Reply With Quote
Old 03-30-2005, 08:51 PM   #6
Send a message via AIM to NJStang86
What kinda stuff you got on your car? 70mm is pretty big and for a car that new I'm wondering if you have enough work on the car to warrant such a big TB.
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 03-31-2005, 09:00 AM   #7
RGR
How much, shipped to 47805 zip code?
As for TB sizes, you can't really "over-TB" a motor like being "over-carbed"
But you need post removal to really use a 70mm on an SPI motor. 70mm
will probably work on any 3.8 combo, but not really be needed for most.
Post removal is even good for a stock TB and unmodified motor, one guy
I know showed 5 RWHP gains from that alone.
Old 03-31-2005, 10:04 AM   #8
What's post removal? Is it easy to do?/How do you do it?
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 03-31-2005, 04:11 PM   #9
[QUOTE=RGR]How much, shipped to 47805 zip code?
Im not exactly sure but I will get back to you.
Old 03-31-2005, 04:15 PM   #10
I have a MAC CAI, BBK 70mm T-body, Motoblue U/D Pullies, Magnaflow dual exhaust, SCT chip, and Bullitt handling system. Its still under construction. A buddy of mine told me that if I put in a bigger MAF that my intake system would get a whole lot more push. He suggested a C&L 73mm mass air meter. Any truth to this?
Old 03-31-2005, 05:51 PM   #11
I would work on the internals of the engine first...
All that air going into a stock intake isn't going to do you any good. It seems like you've got plenty of work done in the air department, now you need to level that out with some engine work.
-Frank-
Old 04-01-2005, 12:42 PM   #12
RGR
Yeah, wait for the cam/porting stuff before you do the MAF.
Then it will help alot. Especially with a stroker. Use a Lightning
MAF, they are cheaper, bigger, and easier to tune.
Old 04-01-2005, 12:47 PM   #13
RGR
#1, how I do it...
#2, I use a cover instead of plugs (looks cleaner)
#3, A true work of art!!! (ABSTRACT ART)
60mm throttlebody on 98GreenStallion Pre-2005 V6 Mustang 23 01-13-2005 05:57 PM
60mm TB adapter harness 97Stallion Pre-2005 V6 Mustang 1 06-02-2004 07:55 PM
11:30 PM
