Diablosport Predators for Sale - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 01-26-2005, 03:21 PM   #1
Send a message via AIM to Machperformance
Diablosport Predator for Sale
Place Predator in Shopping Cart goto Secure Checkout. Enter Code Cm6Tx in the code box click update and receive $60 Instant Rebate.
Free Shipping. This is for only 2 Weeks.
http://www.machperformanceparts.com/mp/products.html
What is the Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
4) Why to get DiabloSport Predator?
The only flash tuner with exclusive FlashForwardTM ability allowing you to download custom tunes via Internet from a nationwide network of ChipMaster Revolution tuners (locate your nearest dealer in our Dealer Locator).
The only flash tuner allowing you to get revision updates via Internet.
The only flash tuner with exclusive FlexAdjustTM technology which allows you to vary the engine and transmission parameters over a wide range.
The only flash tuner with advanced OBD-II scanner capability:
read fault codes (DTCs) and their description in plain English (no need for extra books!)
both standard and proprietary fault code text included
reset fault codes
live data monitoring
The only flash tuner that logs* live data. Play back log on Predator or PC (Log Viewer for Windows is available FREE on our Downloads Page).
The flash tuner with a true graphical display that's 300% larger then the competition's puny text only display
The flash tuner running on a custom high performance, multi-threading KROS operating system
5) Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER! Average power gains are in the 15-20 RWHP range. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs. A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway. The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline. DiabloSport has generated all dyno tested tunes.
Predator tunes re-map the:
Fuel Curves
Timing Curves
Extend Speed Limiters
Extend Rev Limiters
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade or 91 octane fuel only, like carried by Amoco/BP, Sunoco or Mobil.
6) Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because we allow for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predators live data feature to monitor timing and other vital parameters.
The Mustang Predator allows the end user to adjust the following parameters:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
WOT Shift Pressure
Part throttle shift firmness
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
7) Diagnostics and Live Data Logging
The diagnostic feature allows the end user to scan and erase fault codes as well as monitor live data while driving. Predator can read and erase fault codes, and contains all the Ford specific P codes. Predator diagnostics will work on all 1996-2003 OBDII Ford Mustangs or F-Series Gas vehicles. The diagnostics features can be used on any Ford OBDII vehicle, regardless if the tool has locked itself to a specific vehicle or not. Data logging is available as well. Logging stores 30 minutes of data, with slow rate the logging allows for up to 90 minutes. The log can be viewed in Predator, or it can be uploaded to PC for viewing with the FREE DiabloSport DAT Viewer for Windows software (download yours now).
8) PC Interface Kit
PC Interface Kit allows you to connect your Predator to your PC. More information about why would you want to do that is here.
9) Custom Tuning
We can do custom tunes for almost any application without the need for end user to send us the Predator. We have PC interface software available for download and the tunes can be sent via e-mails. Please visit our Custom Tuning Page for more info.
Mach Performance Parts
For Your Performance Auto, Truck, and Suv needs
1-888-434-1099
sales@machperformanceparts.com
Machperformance is offline   Reply With Quote
sct or diablosport 3.8boii Pre-2005 V6 Mustang 50 04-12-2010 05:54 AM
SCT or Diablosport sonicpony03 Pre-2005 V6 Mustang 49 06-05-2008 07:49 AM
Diablo Sport Predators for $341.99 Free Shipping Machperformance Mustang Parts for Sale and Wanted 0 11-28-2004 03:48 PM
Diablosport Predator steedav6builder Pre-2005 V6 Mustang 24 10-11-2004 07:52 PM
sct vs diablosport which one? gforces69 Pre-2005 V6 Mustang 15 10-01-2004 11:01 AM
03:39 PM
