List Of Parts I Need For A V6 - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 02-02-2005, 11:56 AM   #1
All parts must work on a 2002 V6 3.8L Setup
Fuel injectors
fuel rail
TB
MAF and Possible the tubing
fuel system (if i can get it cheap)
Throttle cable and Cruise Cable
let me know what you got
hawks05 is offline   Reply With Quote
Old 02-02-2005, 01:51 PM   #2
Send a message via AIM to NJStang86
I think I can get you the stock intake minus the MAF
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 02-02-2005, 01:59 PM   #3
dont need the intake setup only need the TB and the MAF for that stuff going CAI
Old 02-03-2005, 09:15 PM   #4
Oh I thought you needed the intake tubing...You put in on your list.
my mistake
-Frank-
Old 03-05-2005, 05:56 AM   #5
RGR
Send a message via AIM to RGR
Fuel injectors
fuel rail
TB
I have most of that stuff, need to check
and see exactly what I still have.
oh, my TB is from a 99-00, wasn't there a change
at '01? Email me if interested.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-05-2005, 10:53 AM   #6
you got the throttle cable? and the cruise cable? also what is used on the butterfly valves?
Old 03-05-2005, 11:03 AM   #7
RGR
no, my stuff is 99-00 parts.
I would delete the IMRC's most people do and
it runs great. What are you doing, an SPI swap?
What year is your car?
Old 03-05-2005, 10:20 PM   #8
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I have a TB for sale in another post. It's the same as the TB from a 3.8
4.2 split port engine parts/torque converter/steeda parts
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Building a parts list oaktonarcher 1996-2004 Mustang GT 2 08-21-2008 04:25 PM
Need a list of parts for a I4-v8 swap sonic04edge 1979-1995 Mustang GT 9 08-10-2007 08:29 AM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
Nice list of Engine Parts for V6 Mustangs: Heads, Cams, Intakes... Brent Mustang Parts for Sale and Wanted 22 04-21-2006 03:09 AM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
06:58 AM
