Cam Cores needed for RDMotorsport cam GP - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 02-27-2005, 10:14 AM   #1
RGR
Send a message via AIM to RGR
contact me or Rob, I'll get his email up.
I'm closer to the regrinder(s) so best to send it to me probably.
I'll get with Rob and set a price.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-03-2005, 06:06 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
are these the "wonder cams" like the one I read about where you got an extra 40 horse out of an otherwise stock v6? If so I'm very interested, depending on price.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-03-2005, 09:29 PM   #3
RGR
Yes, that is a best case, a couple people got around 50 HP with
cam and tune! I've put alot of work into the new grinds.
Better all around, are these new lobes!
I'm speccing and RDM is delivering
Old 03-05-2005, 06:53 AM   #4
RGR
Top, WE NEED CORES!!!
cam hp? jeff45 1979-1995 Mustang GT 16 05-06-2007 10:24 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 08:11 AM
what is needed to swap the dual cam v8 mark 8 motor into a mustang gt 1996 MIA1996gt 1996-2004 Mustang GT 1 09-12-2006 10:36 PM
cam and rr? cjd10 Pre-2005 V6 Mustang 16 02-08-2005 05:12 PM
08:31 AM
