Ford C-Springs - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 05-08-2005, 11:35 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Ford C-Springs *still availible*
Ford C-Springs. About 10,000 miles on them. Very good condition. No coils cut. $75
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 05-08-2005, 11:48 PM   #2
not bad, ill link a few people.
Old 05-08-2005, 11:49 PM   #3
Yellow5.0's Avatar
how about 50 plus shipping?
http://www.mustangevolution.com/gallery/data/502/1.jpg1995 GT- GT40 iron heads, 1.72 cobra roller rockers, FMS shorty headers, flows welded in, bbk o/r h, bbk UDP, steeda tri ax, timing advanced to 13, CAI, 75mm granatelli MAF, Eddy performer intake, 17x9 chrome cobra r's, mach 1 chin spoiler
for pics of my car go here-->car pics
Yellow5.0 is offline   Reply With Quote
Old 05-09-2005, 07:53 AM   #4
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
^so $75?
lol, that's about what it'd be
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-09-2005, 08:09 AM   #5
I liek gramer
WhiteStang99's Avatar
I'll take them.
Old 05-09-2005, 08:56 AM   #6
Danger Dude's Avatar
Great price. Good choice there Nick
Old 05-09-2005, 04:38 PM   #7
Dang, should have seen this earlier, O well, I'll just buy the bullitt kit and be done.
Old 05-09-2005, 07:04 PM   #8
I liek gramer
w00t. I win.
Old 05-18-2005, 06:54 PM   #9
Send a message via AIM to charkelly9
used c springs< bullit kit
haha you lose!
charkelly9 is offline   Reply With Quote
Old 05-18-2005, 07:06 PM   #10
actually the C springs are nearly identical in spring rate... actually the C springs will make your car handle better due to they have a better geometry on the car, they lower it 1.2 inchs vs the bullit kits 3/4 of an inch... so C springs > Bullit springs
Old 05-18-2005, 08:44 PM   #11
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
arent c spings what come with the bullit kit?
http://www.stangsuspension.com/store...?idproduct=275
19ClearCobra96 is offline   Reply With Quote
Old 05-18-2005, 08:54 PM   #12
maybe in some kits but the bullit kit usually or should have the bullit springs, which are not c springs
Old 05-18-2005, 09:08 PM   #13
well i donno about you but i dont really wanna buy cc plates so .75in drop is fine with me.. and i was kidding about the bullit kit cause he gets sway bars too so its kinda a better deal if you look at it from that aspect .. haha . nvm
cut the dead coil im sure the springs would be almost identical
Old 05-18-2005, 09:51 PM   #14
You can go all the way to 1.25 and not need C&C plate. Actually Bullitts did not have C springs even though that ad says they do. Bullitts had progressive springs and not specific springs from the factory. More like B springs. But then again there is a possibility I could be wrong but I dont think so
Old 05-18-2005, 10:37 PM   #15
i dont think bullits have progressive springs but who knows. You wont need cc plates with a 1.25 inch drop and if you want any drop at all the bullit drop will leave you wanting more.
Old 05-18-2005, 10:38 PM   #16
Region: Nebraska
thats why I am afraid of buying that setup
Old 05-19-2005, 06:26 AM   #17
My car dropped 1.5 but mine is a 98. For some strange reason most 99+ only drop 1.25 with C springs. This has always irked me that this happens yet I cannot find a reason for it. So if you have A 94-98 you seem to get a slightly better drop than 99+ with C springs. I will also say I needed C&C plates after about 6 months.
OK in doing a little investigating I found Bullitts have C springs but they dont cut the rear dead coil and they use a slightly thicker spacer in the front to get a even 1" drop
Old 05-19-2005, 12:49 PM   #18
ive installed C springs on 3-4 pre 99s and none went over 1.1 most 1.1-1.3 who knows why yours went 1.5 but I definatly wouldnt expect it to.
Old 05-19-2005, 12:52 PM   #19
But you can see my pics my car has a much bigger drop than most with C springs
Old 05-19-2005, 12:58 PM   #20
your car is about as low as mine, and i have a 1.2 drop... maybe the gap on the fender to the tire for pre 99s is more stock... hummm but thats the same gap most Ive installed has which is definatly not 1.5 on 99 up at least.
Old 05-19-2005, 12:59 PM   #21
if you have time and the car is on a flat surface measure from the ground to the edge of where the fender starts I would like to see what that is on your car, see how they compare. Stock seems to be 28.25~
Old 05-19-2005, 01:00 PM   #22
But I measured mine before and after and unless mine was higher to start Like a super 4X4 stang. Mine initially started out at 1.25 but after 6 months it went further and then I needed C&C plates
Old 05-19-2005, 01:05 PM   #23
are those pictures right after the drop or after it has settled.
Old 05-19-2005, 05:00 PM   #24
so still the springs are the same quality just... different drop spectorV...
bullit kit(if you live near snow) > 10000mile used c springs
Old 05-19-2005, 05:06 PM   #25
that extra bit wont matter in the snow and it looks much better so just go with the C springs, heck I am pretty sure they are all made by eibach anyway. I know the C springs are.
Old 05-20-2005, 05:12 PM   #26
I liek gramer
He never got back in contact with me?
Old 06-23-2005, 05:53 PM   #27
Region: Iowa
OK so still not sold. Whitestang backed out. Got them locally from a buddy of his or something. So, back to being for sale... Anyone interested now?
Old 06-23-2005, 06:12 PM   #28
Zim
You want to **** me?
Zim's Avatar
Brandon, the C springs lowered my car 1.5 inches as well. Did a number on my front tires because of it too
I like toys
Old 06-24-2005, 12:17 AM   #29
I liek gramer
Sorry about that Horse.
The drop is perfect and I can attest that it does make a huge difference in handling. In a good way.
Old 06-24-2005, 08:30 PM   #30
My car is now even...at a nice height, around 1.5 if I had to guess. And yes, I need c/c plates now, I can visibly see my toe out.
Old 06-24-2005, 08:32 PM   #31
I liek gramer
I think I can too, but I don't wanna see it.
Old 06-24-2005, 08:55 PM   #32
Mine's pretty noticable...I guess it's time to order some....
*yelling* rob */yelling*
Old 06-25-2005, 11:12 PM   #33
Region: Iowa
Hey, whitestang, no problem. I understand completely.
Old 08-06-2005, 10:38 PM   #34
Send a message via AIM to ocbaud Send a message via MSN to ocbaud Send a message via Yahoo to ocbaud
Re: Ford C-Springs
$75 shipped to 73150???
ocbaud is offline   Reply With Quote
Old 08-07-2005, 12:41 AM   #35
I liek gramer
Re: Ford C-Springs
^ You'd be best off to PM him, if he has it set to email him when he recieves a PM he'll check the site more quickly.
Ford Racing C-Springs BirminghamStang Pre-2005 V6 Mustang 8 12-22-2005 06:49 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 04:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 01:13 AM
Ford Racing C Springs and Stock Rims White6Pack Pre-2005 V6 Mustang 5 09-05-2004 07:31 PM
Ford Racing C Springs....$121?? 02Stang Pre-2005 V6 Mustang 2 05-13-2004 07:27 PM
09:15 AM
