Very Nice Upgraded Vortech V1 S-Trim Kit (FULL KIT!! EVERYITHING)+ GAUGES AND PODS - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 08-28-2012, 07:17 PM   #1
CodyNelson's Avatar
Region: West Virgina
Hey guys as the title says I have to part with my Vortech V1 setup. I made over 400hp with this blower on a stock motor with bolt ons. This is a great starter setup but with the proper supporting mods can easily push 600hp or more!! The kit is on the car and I can try to get a couple pics up for you guys. I will try to list all the parts and upgrades if you have any questions feel free to call/text 304-553-2931.
Vortech V1 S-trim Polished headunit
Upgraded braided steel lines and anodized fittings (WILL NOT LEAK EVER!!)
Custom power pipe
3 Pulleys- 3.33" (8-9psi) , 3.25" (9-10psi), and 3.12" (11-12psi)
Vortech maxflow aftercooler
Upgraded amazing front mount heat exchanger
-at 90*F it dropped my air intake temps 35*!!
Upgraded Cobra coolant pump
Vortech coolant box
SCT BA3000 MAF (can be run draw or blow thru)
Vortech maxflow race valve (sounds amazing!!)
FRPP 42lb green top injectors
Brand new gates belt
All lines, clamps, hoses, fittings included.
**The only thing you will need to purchase is a fuel pump and the bung to be welded on the oil pan for the return line**
I would like to get $3500 for everything. This is a very nice setup and I wish i didnt have to sell it!! My loss is your gain! There are $8000+ in parts if you were to buy each piece!
I also have 3 gauges and the pods to go with them for an extra $300. I have a dual pillar pod and a steering columb pod. The gauges are glowshift tinted 7 gauges. These things are super nice!! Change to 7 different colors and have 3 different settings plus can be wired up to dim when the dash lights come on. I have the digital wideband, 100psi fuel pressure, and the 30psi boost/vac gauges. I personally wouldnt run the blower setup without these. I can text pics of these as well to those interested.
Old 08-28-2012, 08:37 PM   #2
Jake's Avatar
Custom power pipe
Vortech coolant box
Will this fit, s197??
Jake is offline   Reply With Quote
Old 08-29-2012, 09:23 AM   #3
CodyNelson's Avatar
I know you would need a new bracket but I'm really not sure
Old 08-29-2012, 09:50 AM   #4
Jake's Avatar
Alright man, ill try to figure out what all ill need
Old 08-29-2012, 11:15 AM   #5
CodyNelson's Avatar
Re: Very Nice Upgraded Vortech V1 S-Trim Kit (FULL KIT!! EVERYITHING)+ GAUGES AND PO
Ok, thanks for your interest
Old 08-29-2012, 11:18 AM   #6
Jake's Avatar
Im very interested. Ill buy it but i jist need to know what ill need for it to fit
Old 08-31-2012, 07:41 AM   #7
CodyNelson's Avatar
Gauges and pods are sold!
Old 09-03-2012, 07:44 PM   #8
CodyNelson's Avatar
bump, come on I know someone wants to go fast!
Old 09-11-2012, 09:27 AM   #9
CodyNelson's Avatar
BUMP- Price drop to $3300 plus shipping
Old 09-11-2012, 09:35 AM   #10
xhgwx's Avatar
If only I had the money and if only it fit the 3.8L
xhgwx is offline   Reply With Quote
Old 09-17-2012, 05:59 PM   #11
CodyNelson's Avatar
Bump
Old 09-18-2012, 10:14 PM   #12
DaBluedude's Avatar
I'm so tempted by this kit but id have to modify it for my mach. Ill keep an eye on this thread just in case I free up some liquidity.
2003 Mach 1
Old 09-18-2012, 11:13 PM   #13
CodyNelson's Avatar
Shouldn't have to modify much at all. The after cooler already has a 4valve discharge I just have a custom piece connecting it to my 2v intake.
Old 09-19-2012, 06:29 AM   #14
CodyNelson's Avatar
Did some research for you, all you would need to change is the mounting bracket and those can be found pretty cheap
Old 09-19-2012, 12:16 PM   #15
DaBluedude's Avatar
Yeah. Ill let u know if i find some extra cash. I would love to pick up the blower because it's realitively easy to bypass it as my mach sees winter duty. A blower in the snow is a bad plan haha.
2003 Mach 1
Old 09-30-2012, 06:29 AM   #16
sam minnick's Avatar
Do you still have this setup
sam minnick is offline   Reply With Quote
Old 09-30-2012, 08:06 AM   #17
CodyNelson's Avatar
Yes I do
12:14 AM
