4 30lb injectors from turbo coupe - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Closed Thread
Old 10-30-2012, 09:08 AM   #1
32vNomad's Avatar
I have 4 30lb injectors may need cleaning. Pulled from 2.3L Thunderbird Turbo coupe. $80.00 shipped.
32vNomad is offline
Old 11-01-2012, 10:16 AM   #2
Would they be any good on an n/a 2.3l?
93mstnglx is offline
Old 11-01-2012, 01:39 PM   #3
32vNomad's Avatar
I don't see why not. That is if you have mods for the needed fuel. Usually when you change fuel injectors in an engine to ones larger than what the ecm is calibratered for, you waste fuel. Because the larger injector will put more fuel out per cycle. If you plan to go turbo or fi then they would be something to have.
32vNomad is offline
Old 11-01-2012, 03:57 PM   #4
Turbo yes but that is still a long way down the road, thanks tho
Old 11-23-2012, 10:44 AM   #5
32vNomad's Avatar
Bump* These are still up for sale.
32vNomad is offline
Old 11-23-2012, 03:39 PM   #6
2300turboford's Avatar
Their 36lbs I'm pretty sure they will handle 20 lbs
2300turboford is offline
Old 11-23-2012, 04:38 PM   #7
Let me rephrase that their 36lbs injectors and they will handle 20 psi if boost
Old 11-23-2012, 04:52 PM   #8
32vNomad's Avatar
There are the red top Bosch injectors(FMS). The black part wiped off on some because of the cleaner I used at the shop. I was going to use them in my 4v but I only have 5 and switched to the unscar ev6 injectors.
32vNomad is offline
Old 11-23-2012, 04:55 PM   #9
If u weren't so far away I'd sell u my 4
Closed Thread
02:28 PM
