For Sale: HID Kit - 55W 8000K - 9007 bulb- Low beam only - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Closed Thread
Old 04-15-2014, 06:21 PM   #1
Tiffsobelle's Avatar
HID Kit from DDM Tuning.
55 watt - 8000k - 9007 bulb - Low beam - $25
HID Harness - $5
Shipping -$5
(if you buy both, it will only be $5 to ship)
There is absolutely nothing wrong with these; they work just fine.
Description about the harness:
Use this relay harness to connect HIDs to cars with very small gauge wiring that cannot supply the initial surge current required to light the bulbs reliably. Symptoms indicating the harness is required would be intermittent starting or lights going out after being turned on for several minutes and requiring you to turn the lights off and back on for them to turn back on again. Recommended for all 55W HID installations but most American and European cars work at 35W/55W without the harness. The harness is definitely recommended for Quad';s and other ATVs or when running multiple HID installations. This harness is a fused relay isolation harness capable of supplying 20A at 12vdc. Not required when using High / Low kits.
I bought this set and a set for my fogs so they would both match color. However, I have a set of hi/lo's that came on the car when I bought it that I like to use in the headlights instead. Absolutely NOTHING wrong with this set, just plug, play and mount the ballasts. These have maybe 2 hours of use on them, if that.
Thanks!
Tiffsobelle is offline
Old 04-29-2014, 08:03 AM   #2
**Bump**
I will ship the harness and HID kit for $25 (all).
Old 05-19-2014, 06:10 AM   #3
*** BUMP ***
This is the correct pic from DDM Tuning, accidently added the one for the fogs (bulb 9145) oops..
Old 05-27-2014, 10:34 AM   #4
SOLD
Closed Thread
For Sale: '10 -'12 8000k HID Kit Jackal43x Mustang Parts for Sale and Wanted 10 05-25-2013 06:54 PM
HID kit 55w vs 35w whats the difference? gtstyles2 General Mustang Discussion 8 01-27-2013 01:37 PM
H7 55w 6,000k hid kit MachMan1017 Mustang Parts for Sale and Wanted 3 01-24-2013 08:07 PM
09:13 PM
