For Sale: 8.8" Rear End 4.10 Gears with install kit and Gear Oil in Socal - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Closed Thread
Old 12-11-2014, 03:24 PM   #1
willb2305's Avatar
Comes with Ford Racing 4.10 gears, Ford Racing install kit, Ford Racing Axle Bearing/Seal Kit, 2 Quarts of Royal Purple 75W140 Gear Oil. You need 1 more Quart of Royal Purple Gear Oil i thought I had 3 quarts but cant find the 3rd one. Asking $315. Prefer local pickup in Socal but I can do shipping. it will probably be $25 to $45 depending where you live the 410 gear is pretty heavy.
Ford racing 4.10 gears retails for $159.99 up to $199
Ford Racing 8.8inch Axle Bearing and Seal Kit retail for $40 for 05-14 Mustangs
When installing a new set of axles or steeper rear gears in your Pony it is a good time to swap out those old worn Axle Bearings and Seals with a new set. High-quality Ford Racing steel bearings are a direct fit replacement and cheap insurance against an axle failure.
Ford Racing Ring and Pinion Install Kit 8.8inch Rear 86-14 V8, 99-04 CObra, 11-14 V6 Retails for $99.99
This Ford Racing kit comes complete with all the components needed to swap out your ring and pinion gear. It includes pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, Shelby GT500 high-torque pinion bearing, heavy duty carrier bearings, cover gasket and all the required hardware.
Royal Purple Gear Oil retails for $19.99 per quart
Pure Performance. Maximize performance from your Mustang's drivetrain with Royal Purple Max Gear oil. This fully synthetic oil is the perfect compliment to new gears, lubricating better and ensuring your differential keeps working its best whether it has gone a thousand miles or a hundred thousand.
Protect Your Investment. Made with Royal Purple's innovative Synslide® additive, Max Gear oil is perfect for upgrades or routine service. It's the gear oil of choice for greater wear protection and lower temperatures for every car, from daily drivers to track-day toys. It prevents corrosion and meets all warranty requirements, so adding Royal Purple Max Gear oil is great for peace of mind when it comes to your Pony.
Includes Friction Modifier. Unlike other oils, all viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
ID:	171571   Click image for larger version
ID:	171573   Click image for larger version
ID:	171575   Click image for larger version
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline
Old 12-14-2014, 01:57 PM   #2
willb2305's Avatar
lowered to $305
2012 V6
Old 12-17-2014, 09:10 PM   #3
Is $305 the lowest offer you accept?
Dominicano is offline
Old 12-18-2014, 01:14 PM   #4
willb2305's Avatar
price dropped to $294
2012 V6
Old 12-24-2014, 08:12 PM   #5
C_Dailey95's Avatar
Where in socal are you? Maybe interested
C_Dailey95 is offline
Old 12-25-2014, 02:14 AM   #6
Would also like to know, I am located in San Diego.
SR Performance CAI, Diablosport Intune bama tuner, Roush Axleback, Matte black rocker stripes.
Quack is offline
Old 12-27-2014, 09:08 AM   #7
willb2305's Avatar
I am located in Palmdale which is 60 miles south of Los Angeles.
2012 V6
Old 12-27-2014, 09:34 AM   #8
Boosted_3v's Avatar
The lowest? I live in CA I can pick up
Boosted_3v is offline
Old 12-27-2014, 10:47 PM   #9
willb2305's Avatar
pm sent Frankie
2012 V6
Old 12-29-2014, 10:35 AM   #10
willb2305's Avatar
price drop to $280. slightly better deal if picked up locally. I live about 60 miles south of los angeles, cali. Also includes the ford fiction modifier forgot to put that in the original listing.
2012 V6
Old 01-04-2015, 01:03 AM   #11
willb2305's Avatar
price drop to $260 need to sell.
2012 V6
Old 01-10-2015, 10:25 AM   #12
willb2305's Avatar
price drop to $250
2012 V6
Old 01-10-2015, 06:00 PM   #13
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Will you ship?
roushMarlon831 is offline
Old 01-15-2015, 03:03 AM   #14
willb2305's Avatar
price drop to $235
2012 V6
Old 01-20-2015, 10:24 PM   #15
MustangMinded's Avatar
Would that 8.8 fit under my 1998 3.8? I have the stock open differential but with 3.73 I believe so 4:10 would be nice.
MustangMinded is offline
Old 01-21-2015, 10:55 PM   #16
GrabberBlue1993's Avatar
Can you ship? Is it the entire install kit brand new?
Sent from my 831C using Mustang Evolution mobile app
"At least it isn't a Honda"
GrabberBlue1993 is offline
Old 01-23-2015, 05:38 PM   #17
willb2305's Avatar
Yes i can ship it out the whole thing its brand new. Price drop to $230 for whole kit. or $150 for the 410 gear or $179 for 410 gear with 3 quarts of Amsoil Severe Gear Oil. For anyone interested in knowing how much it is to ship out please read below. The whole package is going to weigh around 27-29lbs. The 410 gear by itself weighs 20lbs. So shipping will not be cheap. It was going to cost $23 to ship out from here in Southern california to someone in northern california with Fedex ground which is cheaper then UPS. And for shipping to houston texas i think it was around $35-$40. And to florida it was almost $50. This is one of those items that its better to meet up in person and pick up locally then to ship it out.
2012 V6
Old 04-09-2015, 02:05 PM   #18
willb2305's Avatar
Price drop to $220
2012 V6
Old 04-12-2015, 09:35 PM   #19
willb2305's Avatar
Price drop to $205 with full install kit with either Royal Purple or Amsoil Severe Gear Oil. Or $150 for just the Ford Racing 410 gears, $170 for 410 gears with Gear Oil and no install kit. $195 with full install kit but without gear oil. Either way you are getting a hell of a deal.
The install kit has the following with it:
Ring gear
Pinion gear
Rear Gear Pinion Bearing
Ford Racing Friction Modifier
Front & Rear Pinion Bearing
Pinion Seal
Carrier Bearings
Carrier Shims
Differential Bearings
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Gear-marking compound
Axle Bearing Kit
2012 V6
Old 04-22-2015, 08:15 AM   #20
willb2305's Avatar
bump. Price drop to $200 with full install kit with both Royal Purple and Amsoil Severe Gear Oil sets. Or $150 for just the Ford Racing 410 gears, $170 for 410 gears with Gear Oil and no install kit. $190 for Gears with full install kit but without gear oil. Either way you are getting a hell of a deal and you wont find a better price anywhere on the net especially since its all New Ford Racing Parts. Both sets of gear oil is included since you will need another set of gear oil after your 500 mile break in period. Also I prefer local pickup as the package will weigh around 30-31lbs so shipping wont be cheap. I am located in Southern California near Los Angeles.
2012 V6
Old 05-02-2015, 12:42 PM   #21
willb2305's Avatar
still available. you are getting $360 worth of parts for $200
2012 V6
Old 05-13-2015, 01:48 PM   #22
BeastyStang's Avatar
I am very interested in buying these off from you. I work in South Central LA. But from my understanding the 4.10 gears, and ring and pinion are compatible with my generation mustang (2002). How much would you sell me the gears, ring and pinion and oil?
BeastyStang is offline
Old 06-24-2015, 03:30 PM   #23
Check your dm, I'll take em
Old 06-29-2015, 12:15 AM   #24
Where u at will
Old 06-29-2015, 12:22 AM   #25
Old 06-29-2015, 05:27 AM   #26
Jon3.7's Avatar
You may want to pm him, it's been a couple of months since hes been on this thread
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline
Old 06-29-2015, 06:47 AM   #27
bucko's Avatar
If he does not respond within 24 hours, we will close the thread, making the assumption it has been sold.
bucko is offline
Old 06-29-2015, 07:22 AM   #28
I've pm'd him a couple of times already. Last time I spoke to him was on the 11th. Told him I would get the gears by next week after that no response
Closed Thread
Gear oil in rear wheels after install? runvsofthisbull 1996-2004 Mustang GT 9 03-11-2014 05:28 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
7.5" gear install kit...where to buy? tedness Pre-2005 V6 Mustang 7 10-21-2005 11:02 PM
"Damn cops" and "Damn women drivers" fast64 The Bar 10 11-27-2003 07:18 PM
08:34 PM
