For Sale: BMR Suspension parts for 2011 to 2014 S197, less than 1K miles on them - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 04-14-2016, 11:30 AM   #1
tombrochard's Avatar
Madison Connecticut:
TCA019 - Lower Control Arms, Boxed, Non-adj, Poly Bushings. Retail $139.95
Color – red
Fits 2005 to 2014 mustang
Enables harder launches, reduces wheels hop and makes cornering more consistent
CAB005 - Control Arm Relocation Brackets, Bolt-on. Retail $109.95
Color – red
Launching harder, reducing wheel hop, and repositioning the instant center on your S197 Mustang is easy with lower control arm relocation brackets from BMR Suspension.
UTCA032 - Upper Control Arm, DOM, On-car Adjustable, Poly Bushing $169.95
Color – Black Hammertone
Fits 2011 to 2014 mustang
Launching harder, reducing wheel hop, and adding cornering consistency to your 2011-2014 Ford Mustang is easy with an upper control arm from BMR Suspension. BMR’s polyurethane, on-car adjustable tubular control arm for S197 Mustangs (UTCA032) is manufactured from heavy-duty 1 5/8 inch, 0.120-inch wall DOM steel tubing.
UCM002 - Upper Control Arm Mount $159.95
Color – black Hammertone
Fits 2011 -2014 mustang
Upper control arm mount is a direct replacement for the OE piece and requires no drilling or welding to install. This specific part number is intended for 2011 and newer cars that utilize the larger 18mm mounting bolt and cross-bolt.
SP065 - Lowering Springs, Set Of 4, 1.5" Drop, Handling, GT Retail $239.95
Color – red
Fits 2005 to 2014 Mustang
BMR has designed the SP065 for the handling crowd who regularly use their cars on the road course or for autocross. These springs will drop your S197 Mustang 1.5-inches and feature a fine-tuned spring rate to give you great handling and a smooth ride. The 240 lb/inch front linear spring rates offer plenty of support, keeping the body flat and level in the corners. The 200 lb/inch rear dual-rate spring decreases body roll and gives you a lower center of gravity for increased driver control in aggressive cornering situations.
PHR006 - Panhard Rod, DOM, On-car Adjustable, Polyurethane Bushings Retail $139.95
Color – red
Factory S197 Mustang Panhard rods are made from weak U-shaped stamped steel with soft rubber bushings that allow excessive deflection under load. BMR Suspension’s PHR006 Panhard rod is made 1.25-inch, 0.120-inch wall DOM tubing with TIG-welded chrome-moly tube adapters.
Total Parts new $959.70 retail plus tax and shipping.
Buy for $500 plus shipping or OBO. Selling as complete set only. No trades, sorry. Private message me if you're interested or have questions. You can also call or text 203-645-1779, just please don't call after 8pm Eastern Standard Time. Thanks
ID:	199727   Click image for larger version
ID:	199729   Click image for larger version
ID:	199731   Click image for larger version
tombrochard is offline   Reply With Quote
Old 04-14-2016, 11:50 AM   #2
Red_Menace11's Avatar
PM sent
Red_Menace11 is offline   Reply With Quote
Old 04-15-2016, 02:15 AM   #3
bucko's Avatar
Use the PM please to discuss. These posts place unfair bumps to the thread. It will be removed if it continues.
Old 04-15-2016, 05:07 AM   #4
audioAl's Avatar
Dang!
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 04-15-2016, 08:24 PM   #5
Messaged you, let me know if I need to PM as well!
Ponyboarder is offline   Reply With Quote
Old 04-16-2016, 07:06 PM   #6
HI All, the suspension stuff sold today, thanks for all the interest.
can any of you guys tell me how to pull the post down? I've been looking for almost an our and can't find anyway to edit it or pull it down
For Sale: 2014 Stock 17" Wheels+Tires+TPMS (Less than 1300 miles) lisl12 Mustang Parts for Sale and Wanted 4 11-06-2014 04:12 PM
Less than 800 miles since the oil was changed dailey 2011-2014 Mustang GT 6 07-07-2012 05:45 PM
4 accidents in less than 2 miles tedness The Bar 1 06-19-2005 09:53 AM
04:45 AM
