08-27-2008, 09:11 AM
#1 | | Registered User
| Diablosport tuner for 99-04 mustangs $225 / OBO free shipping I am selling a diablosport tuner for the 99-04 mustang for $225 / OBO, free shipping. It is still in the box, and is brand new. Normally costs $369 from american muscle.
Info: Are you ready to unleash the venomous soul of your Mustang's motor upon the unsuspecting general public? Then prepare yourself for the Diablosport Predator Tuner.
The Predator for the 98-04 Mustang/03-04 Marauder is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predator's internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Diablosport Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER! Average power gains are in the 15-20 RWHP range. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
DiabloSport has generated all dyno tested tunes. DiabloSport Performance tunes require the use of Super Unleaded / Premium grade or 91 octane and higher fuel only, like carried by Amoco/BP, Sunoco or Mobil.
Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predators live data feature to monitor timing and other vital parameters.
The Mustang/Marauder Predator allows the end user to adjust the following parameters:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
WOT Shift Pressure
Part throttle shift firmness
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
Diablosport Predator Diagnostics and Live Data Logging
The diagnostic feature allows the end user to scan and erase fault codes as well as monitor live data while driving. Predator can read and erase fault codes, and contains all the Ford specific P codes. Predator diagnostics will work on all 1996-2003 OBDII Ford Mustangs or F-Series Gas vehicles. The diagnostics features can be used on any Ford OBDII vehicle, regardless if the tool has locked itself to a specific vehicle or not.
Data logging is available as well. Logging stores 30 minutes of data, with slow rate the logging allows for up to 90 minutes. The log can be viewed in Predator, or it can be uploaded to PC for viewing with the FREE DiabloSport DAT Viewer for Windows software (download here)
So unleash the terror within your pistons on those lowly peasants with the Predator Hand Held Tuner from DiabloSport.
The Predator 98-04 Mustang/03-04 Marauder (part no. U7146) is applicable for the following vehicles:
V8:
1998-2004 GT 4.6L 2valve
2001 Bullitt 4.6L 2valve
2003-2004 Mach 1 4.6L 4valve
1998-2001 Cobra 4.6L 4valve
2003-2004 Mercury Marauder
V6:
1998-2003 3.8L
Here are the pics:
08-27-2008, 03:00 PM
#2 | | 03 mustang GT
| Re: Diablosport tuner for 99-04 mustangs $225 / OBO free shipping I would love to have this however I dont have $225 at the moment. Im going to cali next week so I need to save my money for that. Keep me updated on whether you sell it or not. |
08-27-2008, 03:36 PM
#3 | | Registered User
| Re: Diablosport tuner for 99-04 mustangs $225 / OBO free shipping Quote:
Originally Posted by kcfan_2004 I would love to have this however I dont have $225 at the moment. Im going to cali next week so I need to save my money for that. Keep me updated on whether you sell it or not. | I will try and hold on to it for you if possible |
08-27-2008, 03:40 PM
#4 | | 03 mustang GT
Originally Posted by 1badss/sc I will try and hold on to it for you if possible  | Sweet! |
08-29-2008, 02:26 AM
#5 | | Registered User
| Re: Diablosport tuner for 99-04 mustangs $225 / OBO free shipping If you still havent sold it by sept 1 (next monday) i'll buy it |
08-29-2008, 05:49 PM
#6 | | Registered User
Originally Posted by chris098 If you still havent sold it by sept 1 (next monday) i'll buy it | I will let u know VERY soon. U might get this though |
09-12-2008, 01:38 AM
#7 | | 03 mustang GT
| Re: Diablosport tuner for 99-04 mustangs $225 / OBO free shipping did you sell this yet?? |
09-12-2008, 03:42 PM
#8 | | Registered User
Originally Posted by kcfan_2004 did you sell this yet?? | I did. I have 3.73 gears for sale if youre interested. |
09-12-2008, 04:07 PM
#9 | | Registered User
| Re: Diablosport tuner for 99-04 mustangs $225 / OBO free shipping How much?
__________________ 03 GT silver, BBK intake, March underdrive crank pulley, Spec Stage2 clutch, Spec lightweight flywheel, Pypes catless x-pipe, short throw shifter, Cobra wheels, Termi front bumper and hood. |
09-15-2008, 10:17 AM
#10 | | Registered User
| Re: Diablosport tuner for 99-04 mustangs $225 / OBO free shipping i have a diablo, $150 shipped and it's yours 99 and up cars |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | » Mustang Evolution Facebook Fans | | | |
