Buying a 5.0, need to sell some parts - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 05-26-2004, 11:33 PM   #1
Suprman's Avatar
Send a message via AIM to Suprman
Heads/N20/Slicks/intakes/fuel + more,New Stuff Added 6/21
got some parts that have to go! email is Suprman2169@earthlink.net if you want more info or pics.
i can take pictures of anything, just ask.
the list:
RGR Fully NA heads, Fully Ported, Surfaced and Ready to Go! Fully Assembled with Good Springs. Never used, Fresh! $550 + shipping
Super Six cut and weld upper intake and ported lower intake $450 +shipping
Flex 1/2" intake spacer for 94-98 v6 stangs $50 + shipping
BBK 56MM TB - smoothed and half-shafted - Make offer
94-98 TB - Half-shafted and ported by RGR - make offer
NX wet kit for FORD EFI + GEN x-2 kit, used for a very short time, comes with instructions and everything needed. $650 + shipping
MSD Window Switch - all pills and wires needed $SOLD
Head Gaskets - 96-98 style graphite $50 + shipping
Head Bolts - New Felpro $50 + shipping
190 In Tank fuel pump $50 + shipping
#24 injectors $50 + shipping
brand new 8.8 Traction lock unit $175 + Shipping
26/8.5/15 MT slicks SOLD
5.0 60MM TB - SOLD
Stock Fuel Rail and injectors $15 + shipping
Stock 95 15" wheels - all 4, can include tires if needed $50 + shipping
95 v6 crankshaft $30 + shipping
Stock Induction Tubes $20 + shipping
Stock 7.5 rear 2.73 gears - Come pick it up and it's yours!
Stock DS $15 + shipping
Stock crank and WP pullies, and belt from a 95 $25 + shipping
i will be updating this list when i figure out what else i want to sell!
Click On Sig For More Info
http://www.mustangmods.com/data/6447/suprman.jpg
Best 1/4: 15.49@88MPH
Originally Posted by a232stang
SUPRMAN KICKS ***.
Suprman is offline   Reply With Quote
Old 05-26-2004, 11:39 PM   #2
97Stallion's Avatar
hey, does that 60mm TB have the TPS which you have to cut off your old connector and splice in the new one? Or does the standard V6 TPS connector work on it? If you're confused, just take some pics for me so I can see for myself please.
Living one day at a time!
Old 05-26-2004, 11:45 PM   #3
Suprman's Avatar
as of right now it has no TPS, but i have a stock TPS that you have to cut i believe, but RGR posted on that and i can give ya that!
SUPRMAN KICKS ***.
Old 05-26-2004, 11:48 PM   #4
97Stallion's Avatar
what are the chances of you taking a pic for me really quick. I'm asking and hoping to get lucky, cause I also have a 60mm TB and I really don't wanna cut any of my wires. I heard somebody say maybe a 94-95 GT TB would work without modifing.
Old 05-26-2004, 11:48 PM   #5
97Stallion's Avatar
also did you say RGR made a post on this, if so can I get a link?
Old 05-26-2004, 11:57 PM   #6
Suprman's Avatar
oh the TPS is not cut, i believe you have to cut your side of the the connector not the TPS side
SUPRMAN KICKS ***.
Old 05-27-2004, 12:35 AM   #7
Zim
You want to **** me?
Zim's Avatar
how much for the bottle heater?
I like toys
Old 05-27-2004, 05:46 AM   #8
Danger Dude's Avatar
Well I modified a fitting between the V6 wire harness to the 5.0 TPS no cutting wires. But Robert did post at one time a part number of a Ford part that made the conversion or you can cut wires. So there are 3 ways to do this.
60 mm TB is pretty good, here is a how-to:
FORD Part # M-9989-A1 converts V6 TPS plug to 5.0 TB's!!! (no splicing of wires) Supposedly this works...
1. Re-drill bolt pattern for V6 TB pattern (a gasket helps alot)
2. hack off MOST of the throttle arm, leaving the return spring portion,
the shape will resemble a diamond.
3. grind the remaining surface FLAT.
4. weld on MOST of the 3.8 throttle arm, less the return spring portion, just reuse the part the throttle cable hooks to.
5. making the crossover tube larger is a MUST and a big job! 54-55mm at least... that matches the flow rating of the 60mm TB (remember, no shaft to block airflow)
6. Re-use your 3.8 IAC (idle bypass motor)
7. SPLICE in the 5.0 TPS to your 3.8 wiring harness. The 3.8 TPS is "clocked" 90* off from the 5.0 TPS... and does not bolt on to the
5.0 TB. Use the wiring chart below.
Other than that, it is a "simple bolt-on!" (haha)
60mm is also the practical limit for the 3.8 Upper, the "choke point" can only flow about 550 CFM and the 5.0 TB is rated by FORD to flow 535-540 CFM. However you can weld the exterior of a crossover tube and port it
even more, figure about 2 to 4mm smaller being the minimum size for a
given TB. (65mm would need 61 to 63mm, etc.)
5.0 TPS to 3.8 wiring harness wiring schematic: (for use without the Ford adapter)
5.0 TPS colors.................goes to..................3.8 harness
Green/Green..............................................Gray/White
Black/White..............................................Gray/Red
Orange/White.............................................Brown/White
base color/tracer (stripe) color
**** Note! Not all 5.0 TPS's have the tracer color, but it is listed
for those that do.****
When cutting the 3.8 harness wires, leave enough wire on the plug to reinstall it in the future
if the car is ever returned to stock condition. Use butt splices and shrink wrap to connect wires.
Old 05-27-2004, 07:33 AM   #9
97Stallion's Avatar
Sweet thanks Corey, can you take a pic of that adapter you made? I might call later to see if ford even has that part number in stock. Probabaly not living in South Carolina and all.
Old 05-27-2004, 09:14 PM   #10
Suprman's Avatar
i don't want to really split them up, i might have some one that wants the N20 kit, if you want the GenX2 Kit.
SUPRMAN KICKS ***.
Old 05-27-2004, 09:49 PM   #11
Zim
Zim's Avatar
all i really want is the heater... if youre willing to sell just that lemme know
I like toys
Old 05-27-2004, 09:53 PM   #12
Suprman's Avatar
sorry, it would be too hard just to sell all the other stuff!
SUPRMAN KICKS ***.
Old 05-31-2004, 09:28 AM   #13
Suprman's Avatar
bought the 5.0, taking offers on anything!
SUPRMAN KICKS ***.
Old 05-31-2004, 05:24 PM   #14
Suprman's Avatar
well how much are you wanting for it?
$300 + shipping, but you'll have to help me figure out what all goes with the genx2 kit as i bought everything together.
SUPRMAN KICKS ***.
Old 06-01-2004, 04:20 PM   #15
Send a message via AIM to Crispy
How much for the T-Lok and slicks including shipping? Im located in Elmhurst NY 11373
Crispy is offline   Reply With Quote
Old 06-01-2004, 05:38 PM   #16
Suprman's Avatar
tlock is $175 + shipping(heavy, so maybe 20-30) and the slicks with rims are $150 + shipping (shipping is gonna be $60 i think)
SUPRMAN KICKS ***.
Old 06-01-2004, 05:40 PM   #17
Suprman's Avatar
updated with prices and added heads!
SUPRMAN KICKS ***.
Old 06-04-2004, 12:40 PM   #18
Suprman's Avatar
anyone? give me some offers!
SUPRMAN KICKS ***.
Old 06-11-2004, 09:20 AM   #19
Suprman's Avatar
MSD BOx SOLD! come on guys gotta get this stuff outta here!
SUPRMAN KICKS ***.
Old 06-11-2004, 09:26 AM   #20
I want Nitrous for my car. I understand what the NX wet kit is.. but what is Gen x-2 kit?
Old 06-11-2004, 09:41 AM   #21
Suprman's Avatar
it includes the purge kit, heater, all the safty stuff.
this is from the site:
The ultimate nitrous system accessory. Gen-X/GenX-2 accessory packs include all the components you need to make your nitrous system dependable and worry free. Kit includes: fully automatic bottle heater with pressure transducer, fuel pressure safety switch, liquid filled N2O pressure guage, NHRA approved pressure release fitting, NHRA approved blowdown tube, all the electrical connectors and wire needed to complete the installation.
GenX-2 kit includes a purge valve for the NX Ice-Man solenoid.
heres the link: http://www.nitrousexpress.com/Pages/genX.htm
as you see it retails for $440 and the N20 kit retails for $660 its well over 1100 worth of N20 Goodness!
SUPRMAN KICKS ***.
Old 06-11-2004, 10:51 AM   #22
650 for everything is to much for me good luck selling it.
Old 06-11-2004, 11:11 AM   #23
Suprman's Avatar
its cool, if i don't sell it i'll just use it and find $$ elsewhere!
SUPRMAN KICKS ***.
Old 06-11-2004, 12:11 PM   #24
I'll huh drive to ATL and take your rear
Old 06-11-2004, 12:15 PM   #25
Suprman's Avatar
allright, come and get it, its sitting in the wood next to my house!
SUPRMAN KICKS ***.
Old 06-11-2004, 02:40 PM   #26
Need a better price on the Gen2 stuff. Do you take Paypal?
Jayber is offline   Reply With Quote
Old 06-14-2004, 06:52 PM   #27
Suprman's Avatar
i think the kit is sold, but i'll let ya know.
SUPRMAN KICKS ***.
Old 06-14-2004, 06:54 PM   #28
Suprman's Avatar
added and updated list and prices!
SUPRMAN KICKS ***.
Old 06-14-2004, 07:19 PM   #29
nah I need a 8.8 lol Hopefully one of my friends can get me one with 4.10's already in it
Old 06-14-2004, 08:50 PM   #30
Suprman's Avatar
sweet! i kinda wish i would of gone 4:10 in the 6er, but glad i didn't now as i'm done with go and focusing on show! lol i might change the 8.8 with the fox and make the milage a lil better, but i dunno, thing already gets over 30MPG!
SUPRMAN KICKS ***.
Old 06-18-2004, 10:25 PM   #31
Suprman's Avatar
Ttt
SUPRMAN KICKS ***.
Old 06-21-2004, 09:43 PM   #32
Suprman's Avatar
slicks SOLD
5.0 TB SOLD
SUPRMAN KICKS ***.
Old 06-24-2004, 01:19 PM   #33
Suprman's Avatar
gonna do some Ebay auctions soon here, i'll post links when i do!
SUPRMAN KICKS ***.
Old 07-06-2004, 09:54 PM   #34
Suprman's Avatar
Ttt
SUPRMAN KICKS ***.
Buying Non-Painted Parts Bstang03 General Mustang Discussion 1 10-30-2009 10:34 PM
Looking to sell nib parts Cobra GT Mustang Parts for Sale and Wanted 0 05-04-2009 08:25 PM
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
buying a sport bike, need to sell these parts! Suprman Mustang Parts for Sale and Wanted 4 07-18-2004 04:50 PM
Need to sell these parts NOW! juvifan1 Mustang Parts for Sale and Wanted 4 05-11-2004 10:22 PM
02:00 PM
