Steeda Double Hook Clutch Quadrant For Sale - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Old 06-07-2004, 08:59 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Steeda double hook clutch quadrant, I used this to remove a good inch or so from the travel of my clutch pedal, as well as lower the height of the pedal using a large washer as a spacer.
Also eliminates the weak plastic stock quadrant for more consistant clutch engagement.
You'll need to buy from Steeda one or both of these to make it work:
Steeda Firewall adjuster, part number: 555-7021
and/or
Steeda adjustable clutch cable part number: 172-0000 for pre-'96, 172-0201 for '96 and newer
Would like $20 + actual shipping, (should only be a couple dollars)
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-07-2004, 11:42 AM   #2
Send a message via AIM to Black00GT
10 shipped
2003 Silverado Z71
Mods:
K&N filter, Black diamond plate toolbox, and billet grille on the way.
Future mods:
6" lift kit, rims and tires, Catback, Rhino lining, System
Black00GT is offline   Reply With Quote
Old 06-09-2004, 12:53 PM   #3
2003 Silverado Z71
Mods:
Future mods:
Old 06-09-2004, 02:32 PM   #4
Region: Iowa
I PM'ed you
Old 06-11-2004, 01:30 PM   #5
Region: Iowa
Anyone feel like doing better than $10?
Old 06-13-2004, 04:03 PM   #6
so how does my offer sound now???
2003 Silverado Z71
Mods:
Future mods:
Old 06-14-2004, 08:02 AM   #7
Region: Iowa
Sold.
EDIT:
But since I can't get a hold of him anymore, and I still haven't seen a check, I'm still selling it.
I will also include the small spacer I built for it and the two bushings that I drilled to fit the post so you can lower your pedal to the height of the brake pedal, and still get the cruise to work.
15+ shipping.
Old 07-06-2004, 03:19 PM   #8
Region: Iowa
^^^^^^^^^bump
Old 07-09-2004, 09:20 AM   #9
Region: Iowa
Anyone?
Old 03-16-2006, 06:31 PM   #10
Region: Iowa
Re: Steeda Double Hook Clutch Quadrant For Sale
anybody at all? $15 shipped
Old 03-17-2006, 10:50 AM   #11
meteorachick's Avatar
if you have been tryin to sell this for like a year and a half, just ebay it
Modified 2004 V6
05-08 Steeda Triax Shifter for sale 07GT 2005-2010 Mustang GT 4 04-04-2008 10:15 AM
Steeda Strut Tower Brace For Sale 07GT Pre-2005 V6 Mustang 0 03-24-2008 02:02 PM
Steeda Clutch Cable Kit In2dreamingbig 1996-2004 Mustang GT 5 09-01-2006 06:05 PM
Need help with Clutch Quadrant? 00vertstang Pre-2005 V6 Mustang 5 12-29-2005 05:59 PM
steeda clutch cable chipshot101 1996-2004 Mustang GT 3 04-24-2005 11:37 AM
08:12 PM
