4.2 split port engine parts/torque converter/steeda parts - Mustang Evolution
Go Back   Mustang Evolution > Mustang Classified Forums *20 Posts Required* > Mustang Parts for Sale and Wanted
Closed Thread
Old 07-23-2004, 09:45 AM   #1
Horse is unknown around these parts
Send a message via AIM to Horse Send a message via Yahoo to Horse
Steeda Shift knob, red the unpainted style with the S machined into the top and black rubber around the grip. $25 +shipping
Steeda double hook clutch quadrant $25 +shipping
All engine parts come from a 2000 4.2 F150 motor in good working order.
4.2 F150 Torque converter, looks to be in good condition.
$65+shipping OBO
Split port heads with springs and valves $250+shipping
pushrods and lifters could be included for a little extra.
Split port lower $150+shipping
Split port Upper $200+shipping (supposed to be better then the 3.8 upper, but won't clear the factory hood)
Stock 4.2 pistons and Rods
SOLD
4.2 cam (good as a cheap upgrade for a 3.8) $50+shipping
4.2 TB 60MM $60+shipping
I'll half shalft it for $15 more
'00 TB gasket $10
Various other parts, alternator, fuel lines&rail, waterpump, headers, IAC, EGR, etc.
PM if you're interested in any of the odds and ends and we can work something out.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline
Old 08-13-2004, 08:07 AM   #2
anyone interested in making any offers on any of this stuff?
Horse is offline
Old 08-13-2004, 08:20 AM   #3
dark's Avatar
dark is unknown around these parts
Send a message via AIM to dark Send a message via Yahoo to dark
i wish i had the $ for the upper and lower, since i hope to build a 4.2 turbo this coming year, but right now i can't afford it
I don't own a mustang at the moment
dark is offline
Old 08-13-2004, 08:21 AM   #4
Well, the way it's going I may still have them
Horse is offline
Old 08-17-2004, 12:04 PM   #5
DerickATM is unknown around these parts
don't suppose you're selling the 4.2 block???????????????
DerickATM is offline
Old 08-17-2004, 12:06 PM   #6
Well, eventually I'll have an extra block from my 3.8. The 4.2 and the 3.8 use the same block
Horse is offline
Old 08-17-2004, 12:08 PM   #7
yeah i know...........im looking for a good used f150 short block.
i already my split port heads and intakes.
im trying to avoid stroking but i may have to
Old 08-19-2004, 06:17 AM   #8
1995whitestang is unknown around these parts
Send a message via AIM to 1995whitestang
you happen to have a 4.2L crank to go with those rods/pistons?
1995whitestang is offline
Old 08-20-2004, 12:18 PM   #9
Well, I do, but I'm going to be using that for MY stroker.
Horse is offline
Old 08-31-2004, 08:40 AM   #10
bump
Horse is offline
Old 08-31-2004, 08:56 AM   #11
97Stallion's Avatar
97Stallion is unknown around these parts
Can you take a picture of everything and send them to me. I need to piece some stuff together.
Living one day at a time!
DAMN Those are some old ass numbers!!! I need updated ones!!
97Stallion is offline
Old 09-07-2004, 04:45 PM   #12
Currently all of it is stil attached to the motor. I haven't taken it apart yet.
Um... Let me know if you want just a pick of the motor. I can probably con my friend into taking a digi pic for me.
Horse is offline
Old 10-05-2004, 01:35 PM   #13
bump
Horse is offline
Old 10-05-2004, 03:03 PM   #14
97Stallion's Avatar
So do you still have all this attached to the motor still?
Old 10-06-2004, 10:54 AM   #15
No, the Heads and intakes have been pulled. I still have them but it's apart now. The fuel rail is off. I should be able to get a digital pic by next week.
I can get a pic of the fuel rail assembly for you.
Horse is offline
Old 10-07-2004, 09:46 AM   #16
04V6STANG is unknown around these parts
Send a message via Yahoo to 04V6STANG
So all this stuff will bolt on to a 3.8?
89 Notchback 302 auto
04V6STANG is offline
Old 10-08-2004, 01:34 PM   #17
the lower intake is the same as the 01+ lower intake, with the IMRC's, the upper is totally different. It will bolt on, but won't clear a factory hood, from what I have read. The heads would bolt, and are also split port. The waterpump looks to be exactly the same too. The TB will bolt on to a 99+. All the steeda parts are for mustangs.
Horse is offline
Old 11-07-2004, 12:38 AM   #18
if you still have rods/pistons email me the best price you do on them.
email - jcvince17@hotmail.com
1995 V6 5 Speed
Project Car
Old 11-10-2004, 04:31 PM   #19
chrismullins99 is unknown around these parts
Send a message via AIM to chrismullins99
any gains with using the f-150 cam?
chrismullins99 is offline
Old 11-10-2004, 06:01 PM   #20
97Stallion's Avatar
The 4.2 cam will net you minimal results, but they are still slightly better
Old 11-11-2004, 10:31 AM   #21
what maybe 10 hp?
Old 11-11-2004, 10:35 AM   #22
97Stallion's Avatar
ya maybe, you're better off with a reground cam from someone else though
Old 11-14-2004, 09:57 PM   #23
It is true that a reground cam would be better but for cheap you can pick up a 4.2 one. I remember reading on 3.8mustang, quite a while ago that the 4.2 cam could get you about 15 more ft/lbs of torque, but not a ton of HP.
Horse is offline
Old 01-18-2005, 09:43 PM   #24
Justang is unknown around these parts
Send a message via AIM to Justang
back from the dead. Would you happen to still have headers? and do they have the ports on them for the smog pump (on the passenger side manifold.)
'00 4.2L 5-speed, RPM Ported BV heads & intakes, 207/215cam, all the bolt ons, 3.73's.
265rwhp 280rwtq
Justang is offline
Old 01-20-2005, 09:59 PM   #25
Yeah, I have the stock exhaust manifolds from the F-150 motor. And... From memory, yeah, they have the port there on the passenger side one. The tube that runs to the EGR valve. I can't remember if there's anything else. I can call my dad and have him take a look at them to let you know for sure.
(I moved out and the motor is still at home.)
I'll let you know as soon as I can.
Horse is offline
Old 01-22-2005, 12:21 AM   #26
cjd10 is unknown around these parts
whats the difference between the pistons and rods in a 4.2 and a 3.8
cjd10 is offline
Old 01-22-2005, 12:36 AM   #27
01mineralgrey6's Avatar
01mineralgrey6 is unknown around these parts
if im not mistaken the rods are a little longer for the 4.2, not sure about pistons
-Tony
'99 cobra 'vert
01mineralgrey6 is offline
Old 01-22-2005, 12:44 AM   #28
Brent is unknown around these parts
both pistons and rods are longer
Find us on: Reddit | Facebook | Twitter
Brent is offline
Old 02-20-2005, 09:09 PM   #29
Pistons are sold... Everything else is up for grabs though... Come on. You want this stuff... you know you do.
Horse is offline
Old 02-27-2005, 09:12 AM   #30
RGR
RGR is unknown around these parts
Send a message via AIM to RGR
We could use that cam as a core, for our regrind program.
Hey Horse, give us that cam core and we'll make you a great deal on a cam
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline
Old 05-26-2005, 09:46 PM   #31
Anyone? Anyone at all want any of this stuff?
Horse is offline
Old 09-27-2005, 07:00 PM   #32
Re: 4.2 split port engine parts/torque converter/steeda parts
bump
Horse is offline
Old 03-16-2006, 06:32 PM   #33
Still looking for takers.
Horse is offline
Old 03-17-2006, 04:03 PM   #34
RGR
I will buy the cam core, how much would you take, shipped?
what else you got?
RGR is offline
Closed Thread
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
single port to split port conversion NorwegianMustang Pre-2005 V6 Mustang 3 06-19-2006 03:19 PM
Single Port ---> Splitport Parts needed Brent Pre-2005 V6 Mustang 6 02-10-2005 03:43 PM
My terminology for single port and split port RGR Pre-2005 V6 Mustang 0 01-03-2004 10:03 AM
01:39 PM
