lowering springs - Mustang Evolution
Old 05-15-2009, 09:44 PM   #1
lowering springs
so what lowering springs should i get? all the ones i see lower about the same height but i want something that will work well for me at the track. i will be be doing some launching on drag radials.
jroc07gt is offline   Reply With Quote
Old 05-15-2009, 10:33 PM   #2
upton7's Avatar
Re: lowering springs
eibach drag launch i think they are called check em out at americanmuscle.com
Old 05-16-2009, 12:06 PM   #3
hottcobra's Avatar
the drag launch springs don't lower the car. really lowering springs and drag racing don't mix. But that's ok. I run 275/40R17 MT ET street radials and don't have any problem hooking up. But I run an auto trans and stock converter. these are the springs I run. they work and look great. and the price is right.
Summit SUM-720101 - Summit® Lowering Spring Kits
Old 05-16-2009, 09:05 PM   #4
well i do wanna close up the wheel gap some but i dont wanna hurt myself with launching at the track.
Old 05-16-2009, 09:16 PM   #5
hottcobra's Avatar
it just depends on what you want more. ET or good looks. but it's not gonna hurt that much.
Old 05-17-2009, 07:26 PM   #6
lowering and drag racing dont mix but if you want to try to do the best you can get softer springs in the back and stiffer in the front for weight transfer
Old 05-19-2009, 11:26 AM   #7
hmmm this is gonna be work. would it be best to just not lower the car? overall i would like the car to launch better without sacraficing some ride comfort. however, i wouldnt mine if it closed the gap any.
Old 05-19-2009, 11:31 AM   #8
hottcobra's Avatar
well what mods do you have now?
Old 05-19-2009, 11:38 AM   #9
stock at the moment. thursday i go to tps to get jlt cai and tune. very soon i will be getting 4.10s, bmr radiator support bar/front sway delete, subframe connectors, adjustable rear lca, and drag radials. i wanna try to scratch 12s with only a cai/tune as power mods.
Old 05-19-2009, 12:08 PM   #10
hottcobra's Avatar
auto or stick?
Old 05-19-2009, 12:09 PM   #11
auto or stick?
stick
Old 05-19-2009, 12:20 PM   #12
hottcobra's Avatar
I good set of tires and you can hook with no problem. even with lowering springs.
when you start making big power then you might want to switch to drag springs.
Old 05-19-2009, 12:28 PM   #13
i just want to make sure i can get out the hole hard enough to hit 12s with minimum power mods.
Old 05-19-2009, 12:30 PM   #14
hottcobra's Avatar
good tires and a clutch that can handle 5k launch and your their.
Old 05-19-2009, 12:52 PM   #15
I have the H&R sport springs on mine and on the nitrous I would cut consistant 1.5x 60fts and with the super charger I cut a 1.45 60ft using a set of 275/60/15 et drag radials. the rest of the suspension is bmr lowers, bmr upper, relocation brackets, QA1 adj shocks , and I also have a bmr sway bar delete.
06 GT Vista Blue w/ghost flames/Dark Charcoal Auto,jba l.t. off road h-pipe,mac mufflers,4.10s,xcal II ,12lbs of saleen supercharger boost,ptc 2400 stall,wifes daily driver,10.80@124.41
Spiers is offline   Reply With Quote
Old 05-19-2009, 12:59 PM   #16
tthats about the same bmr stuff i was looking at. im thinking of just getting a set of drag radials for my stock wheels for now.
Old 05-19-2009, 01:02 PM   #17
Yeah I am happy with it and since you know Kent you should know who Omar is , I bought the springs,upper,lowers,bmr driveshaft loop,the relocation brackets, and the QA1's from him for 500 bucks man I couldnt pass it up.
Old 05-19-2009, 01:09 PM   #18
i hear them talk about omar all the time. im looking for some wheels locally if you know of anyone.
Old 05-19-2009, 01:10 PM   #19
What you looking for? Anything in particular?
Old 05-19-2009, 01:10 PM   #20
hottcobra's Avatar
what kind of wheels are you looking for?
Old 05-19-2009, 01:12 PM   #21
a nice staggered set of 18s with tires preferably. i been looking at a set on wheelreplicas.com but idk
Old 05-19-2009, 01:13 PM   #22
hottcobra's Avatar
oh I thought you were talking about bigs and littles for the track.
Old 05-19-2009, 01:13 PM   #23
lol nah not yet
Lowering Springs explicitrock Mustang Audio & Video 3 04-14-2010 06:59 PM
Lowering Springs MRACING 2005-2010 Mustang GT 1 01-11-2010 03:11 PM
Lowering springs Kryptonite 1996-2004 Mustang GT 3 11-27-2006 02:29 PM
Lowering Springs douGT 1996-2004 Mustang GT 10 02-28-2005 10:16 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
02:39 PM
