PCV system delete - Mustang Evolution
Old 05-17-2009, 10:37 PM   #1
hottcobra's Avatar
PCV system delete
As many of you know the PCV system on the 3V mustang is great for sucking oil into the intake system. instead of adding a oil catch can like others have done I decided to get rid or it altogether. this is what I used.
If anyone else is interested here is the parts list:
3/8" K&N Breather (Passenger side) 62-1320*
5/8" K&N Breather (Driver's side) 62-1340
3/8" Vacuum Cap (C&L Intake Tube) 660-1698 NAPA
5/8" Vacuum Cap (intake manifold) 660-1696 NAPA
Central Florida Motorsports - Mustang Performance Parts & Accessories
Old 05-18-2009, 12:54 AM   #2
upton7's Avatar
Re: PCV system delete
should and could i do it to mine
Old 05-18-2009, 09:49 AM   #3
The Darkside's Avatar
confused hotcobra......why did you do that? what is that advantage? What problem are you trying to solve.
i unfortnently have no knowledge or even reference point to what you wrote.
thanks!
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-18-2009, 11:19 AM   #4
hottcobra's Avatar
the PCV system on the 3V sucks and is real bad for sucking engine oil into the intake system.
PCV= positive Crankcase Ventalation
what it does is uses engine vacumn to remove crankcase pressure.
instead of sucking oil into the air intake of my engine I used old school breathers to let the naturally vent the pressure off.
Old 05-19-2009, 08:22 AM   #5
Yeah I did the same on mine. It really got bad after I put the blower on, I guess stuffing 12lbs of boost down her throat she had to have something come back up. That oil in your intake tract will down grade your octane rating with a quickness and with the set-up I was running I couldnt take any chances.
06 GT Vista Blue w/ghost flames/Dark Charcoal Auto,jba l.t. off road h-pipe,mac mufflers,4.10s,xcal II ,12lbs of saleen supercharger boost,ptc 2400 stall,wifes daily driver,10.80@124.41
Spiers is offline   Reply With Quote
Old 05-19-2009, 10:13 AM   #6
jimbullit's Avatar
hottcobra-`and since the install-can you tell the difference?
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 05-19-2009, 11:31 AM   #7
hottcobra's Avatar
not yeah
Old 05-19-2009, 04:33 PM   #8
rugedraw's Avatar
Send a message via Yahoo to rugedraw
Great idea; thanks! I like that MUCH better than the stupid can I've had in my trunk for months which I haven't installed. I'm going that route this weekend. Thanks for the info!
'05 Legend Lime Mustang GT (Steeda CAI, Steeda UDP's, BamaChips 93 tune Via Diablo, ceramic headers, o/r h-pipe, FlowMaster axle-backs, 3.73 gears, alum. f/w, CHE brace w/ torq. lmtrs, UCA & LCA's)
rugedraw is offline   Reply With Quote
Old 05-19-2009, 04:42 PM   #9
hottcobra's Avatar
no problem
Old 05-19-2009, 05:53 PM   #10
jimbullit's Avatar
Wow-I sure am glad for the 'makes-a-lot-of-sense upgrades'-that won't cause you to pawn the furniture..
Old 05-19-2009, 09:41 PM   #11
upton7's Avatar
Old 05-19-2009, 09:47 PM   #12
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Good deal, I actually just started researching this a few days ago because after my intake install I noticed a little bit of oil on top of my throttle body, I was like wtf? Then I found out the PCV is the culprit on these 3Vs.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 05-19-2009, 09:57 PM   #13
hottcobra's Avatar
not really. you actually have PCV valves on your car that stop the oil. the 3V doesn't
Old 05-19-2009, 10:10 PM   #14
? I don't have any PCV valves on my 3V
Old 05-19-2009, 10:15 PM   #15
Our PCV valves are piles of **** and don't stop anything.
Old 05-19-2009, 10:21 PM   #16
lol, actually your right, I had problems with oil getting into the intake manifold with my 2000 V6!
Old 05-19-2009, 11:36 PM   #17
hottcobra's Avatar
At least they tryed to stop the oil by installing a PCV valve. They didn't even bother on our cars. Not even a baffle inside the cam cover.
Old 05-21-2009, 12:10 PM   #18
after researching this type of thing ive decided against it, the unmetered air and such just not something I want to deal with
Old 05-21-2009, 01:22 PM   #19
SaleenFiend's Avatar
I ran a breather system on my 01 Cobra, but I have yet to look into it on the 04 Cobra. What kinds of issues are the pros/cons on our cars Spector?
Old 05-21-2009, 01:37 PM   #20
Same as with any other car. The potential for oil vapor smell and light oil coating of the engine and the fact that unmetered air will be pulled in through the breathers. There is nothing special for our cars that isn't also true on any other car running breathers.
Old 05-21-2009, 02:24 PM   #21
I didn't know whether or not the FI would make an effect.
Old 05-21-2009, 02:53 PM   #22
Nah, just increases the amount of oil/air moving in either direction.
Old 05-26-2009, 12:14 PM   #23
jimbullit's Avatar
Thanks, SpectorV-for staying cautionary-I-duh-had not considered the unmetered air
Questions about pcv valves zack1134 1996-2004 Mustang GT 1 02-20-2009 03:20 PM
pcv venting??? svtlx 1979-1995 Mustang GT 2 01-13-2009 07:45 PM
PCV delete questions wendyc Pre-2005 V6 Mustang 10 02-06-2005 11:14 PM
PCV delete kit breathers 97Stallion Mustang Parts for Sale and Wanted 0 09-04-2004 03:32 PM
09:59 AM
