tuneing issue? - Mustang Evolution
Old 05-26-2009, 12:22 PM   #1
BaginDVS1's Avatar
tuneing issue?
have a 05 gt. clutch was replaced, the other day. car put back together.
now check engine lght is on. low idle speed. there is also reference to a vacum leak. bad IAC. the exhaust is after market. the car does not sound the same at all. much more quieter then before. kicks and bucks in first gear, at low speeds, like rolling allong in traffic then hitting throttle to pick up speed. wants to stall if ac is on at a stop while idleing.
BaginDVS1 is offline   Reply With Quote
Old 05-26-2009, 12:30 PM   #2
hottcobra's Avatar
Re: tuneing issue?
what is giving you the ref. to vac. leak and bad IAC?
also nothing involved in a clutch swap should have anything to do with the way the engine idles.
You need to check over everything that you touched on the car to see if anything is out of place.
Old 05-26-2009, 12:43 PM   #3
BaginDVS1's Avatar
Re: tuneing issue?
it is my girl friends car she got the codes read, i dont have the paper with me. i am just going off of what i remember from the other day. i actually wrote this whole long post with all the info the other day, but it never posted up. kinda pissed.
i didnt think the clutch replacement itself was the problem, but i think the work when done might have upset something, ie something not hooked up fitting broke anytihng like that.
what does the IAC mean/is. never heard of one. what does it do. i have had onwed and worked on subarus. i just replaced my clutch the other day kinda cut and dry, i would imagine it was the same for the mustang. but i do know that anytime you work on something it can open a can of worms somewhere else. if it is a vacum leak how does it affect the car. willl it give low idle speed. does it only affect car it idle or loww rpms?
i heard if the wire harnesses for the o2 sensors were flopped that could b a problem too.
another thing, if the ecu was tuned, and the battery was kept out for like a few days, can that have any effect on the cars ecu, will it go into soem safe mode while it recalibrates, or is that just bs. i cant see how a fuel map will be changed by diconnecting the battery. you can see i have a lot of ??????????? i am just trying to troubleshoot a car i am not familiar with. just want to be sure it is one thing and not 2 seperate things going on.
Old 05-26-2009, 12:55 PM   #4
hottcobra's Avatar
Re: tuneing issue?
the IAC= idle air control valve. it could very be that they damanged the o2 sensor or the wiring. also check for any exhaust leaks before the o2 sensor. that will make the car think it's running lean.
Old 05-26-2009, 01:09 PM   #5
BaginDVS1's Avatar
Re: tuneing issue?
where can i go(like on line) too find a schemetic for this vacum system? is there on out on this site, or should i look for it form the ford company. is there something like the haynes book out there or something for reference like that.
Old 05-26-2009, 01:34 PM   #6
Re: tuneing issue?
Out of curiosity, who did this clutch swap?
Old 05-26-2009, 01:41 PM   #7
Re: tuneing issue?
if all the electrical connections are not plugged back into the transmission when it was put back in this can cause major driving issues.
Old 05-26-2009, 01:53 PM   #8
BaginDVS1's Avatar
Re: tuneing issue?
her brother did the repalcement. he works on trucks and jeeps.
Old 05-27-2009, 01:21 PM   #9
The Darkside's Avatar
Re: tuneing issue?
no ofence but he didnt do a very good job lol
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-27-2009, 01:35 PM   #10
BaginDVS1's Avatar
Re: tuneing issue?
actually he did, considering the parts ford had him use broke. he had to do it twice. he asked for all the parts needed and they gave him the wrong stuff. then there was awhole who did what wrong, and it came out it they screwed up on there end. the project has been going on for like a month. we just dont think the clutch install, and this problem are totaly related.
she is almost ready to junk it over this, and get something else.
it is funny though my dad has always had fords, and every time you went to do something five other problems creep up. it just sucks that they jam everything in this car so close together you cant get at, or look at anyting with out taking the car apart.
ooh yeah why the hell would you tie your clutch and brakes together?
Old 05-27-2009, 01:46 PM   #11
Re: tuneing issue?
ok i take it back lol sorry you had so many problems. i hope it works out.
i bleed Race fuel!
Old 05-27-2009, 01:53 PM   #12
BaginDVS1's Avatar
Re: tuneing issue?
in the middle of driving it after it was fixed the first time the throw out/ slave cylinder bearing went. that is how i saw the brakes and clutch were tied together. the new one just put in blew apart, it was fun driving that with no clutch for like 5 miles. kinda funny though you really only need it to start the car.
where does this IAC valve mount hard to look at hard to get off?
where does the vacum system in the car all tie together.
Old 05-29-2009, 09:36 AM   #13
BaginDVS1's Avatar
Re: tuneing issue?
heard a neew thing, is this true or some truth to it.
i was told that the 05 has a recall on the ecu, becasue if the power is lost for a certain amount of time the car will run horrible. needs a reflash from dealer to fix.
i know taking the battery out does not always do this, but i was told it has something to do with this particular year.
Old 05-29-2009, 04:35 PM   #14
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: tuneing issue?
i don't have an 05 vin, but you can pull up fords site and check for recalls with your cars vin...
Recall Information - Ford
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 05-29-2009, 07:26 PM   #15
BaginDVS1's Avatar
Re: tuneing issue?
thanks but there was nothing.
found this i am gonna try this, she does have a k&n drop in filter.
hope this is it. did the engine code read and it did say something about a bad IAC valve. now i know what it is.
check it out.
http://www.moddedmustangs.com/cleaning-your-iac.html
Old 06-02-2009, 05:28 PM   #16
BaginDVS1's Avatar
Re: tuneing issue?
i dont think their is one, well at least nothing that looks like one. another thing leads me to believe there is not one becasue the 05 has a drive by wire throtle body. there is a servo that operates the butterflys. so why would you need an IAC valve when the computer can kill 2 birds with one stone so to speak. IAC, would be neeeded if the throttle body was cable operated. air can not get arounf throttle body with old style. now it has a servo operate it so the computer can open and close it at idle.
please correct me if i am wrong.
Old 06-05-2009, 08:20 PM   #17
Ninethourpm's Avatar
Re: tuneing issue?
I dont know about 05 but mine is on the throttle body itself.
All over the freaking place would be the short answere.
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 06-08-2009, 05:53 AM   #18
BaginDVS1's Avatar
Re: tuneing issue?
ok here it is, the whole problem was fixed by, get this, cleaning the throttle body.
works just fine now. the throttle body servo was taken off clkeaned off, and no problem.
car runs like it should does not stall out.
went to a dealership to find out if this is a reeal problem, and i should have known better then to ask there, but they said no, and you should never have to clean that, and you should never have to clean the masss air flow sensor, and basicaly i got all the gloom and doom bull**** that comes with asking them. now the throttle wont work, it should be replaced now, and alll that bs. nothing is going to work right becaseu they did not do it. ok, thanks i told him.
Old 06-08-2009, 07:06 AM   #19
Re: tuneing issue?
dont blame the car for work that wasnt done right, if someone doesnt work on that type of car often then the chance they messed up is always there. I know I wouldnt want to jump into a clutch swap... just the price to pay to have it done cheaper than a normal shop but... who is to say that a normal shop wouldnt mess it up either.
Clearance issue? bobbyoooo 1996-2004 Mustang GT 3 01-23-2009 07:08 PM
'98 A/C Cluth Issue matthews.stang Pre-2005 V6 Mustang 3 05-03-2007 05:46 PM
speedometer issue.. MonteCitan 1979-1995 Mustang GT 3 08-15-2006 05:14 PM
need help with a serious issue Kyle The Bar 13 04-22-2005 07:48 PM
Getting The Last Issue Dan The Bar 7 01-14-2004 02:54 AM
07:18 AM
