driveshaft, carbon fiber is awesome - Mustang Evolution
Old 05-29-2009, 01:10 PM   #1
BaginDVS1's Avatar
like high tk, no vibrations, light weight, added power, durrable parts.
here is something to look at.
was reading about this company and some guys that used their parts, seeems a pretty easy thing to do, especial mustangs beind rwd.
the whole premise is the the less weight you have on the rotational mass the more power you can make. plus it is something relatively easy to put on.
check out these links. just some info.
the first link is the company. pretty interesting.
the last on is more of a dyno and rive test.
ACPT Advanced Composite Products & Technology - industrial composites, rollers, driveshafts
http://reviews.hspn.com/articles/111...html/print/111
CF Driveshafts? - i-Club
ACPT CF Driveshaft came in!! - i-Club
i-Club - View Single Post - ACPT Carbon Fiber Driveshaft Test
BaginDVS1 is offline   Reply With Quote
Old 06-01-2009, 08:02 AM   #2
jimbullit's Avatar
Re: driveshaft, carbon fiber is awesome
OkayThanks for all of the fine information and research-very informative stuff Too bad we don't have the fabulously exuberant GT owner-that installed one in his/her `stang. I have considered this-as a "next possible" modification, too. I hope we have a member that has done this mod'-and can give the same rave review(s) like the Impreza doods
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 06-01-2009, 04:26 PM   #3
SaleenFiend's Avatar
Yea, reducing rotating mass is going to make for a lighter/faster revving engine. Just like adding an aluminum flywheel. Aluminum is great and Carbon fiber is better when you consider weight savings.
Old 06-02-2009, 07:18 AM   #4
BaginDVS1's Avatar
plus it reduces wears on parts due to deflection. which i thought was kinda cool. along with the vibration absorbtion.
Old 06-03-2009, 08:10 PM   #5
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
was kinda confused about the site, do you have to call to have somethin made? or do they make parts on a regular basis?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-04-2009, 07:38 AM   #6
its over priced for what you get vs aluminum~ no real need to go that far plus over time CF can start to separate.
They do help, not a huge amount (unless you are making a ton of power) but they do help. Rotating mass is about equal to 1lb of rotating mass per 10lbs of dead weight.
Old 06-04-2009, 04:21 PM   #7
jimbullit's Avatar
Hmmm-since aluminum produces a favorable result-at a lower cost-and doesn't:disintegrate `Seems like al-you-minimum might be the way to hang. Anyone have the experience with the metal driveshaft to jump in here? +/- What are they:
Old 06-04-2009, 04:52 PM   #8
BaginDVS1's Avatar
cf splinters but only after it breaks n a crash, which is a good thing cause it doesnt have a chance to come throught the floorboards. it takes alot to break cf. i think you would break gears bfore you would shred the driveshaft.
aluminum is good but transmits vibration, and causes deflection, which causes wear.
eeh the cf looks cooler anyways, eventhough it hangs out on the bottom of your car and you dont get to see it.
Old 06-04-2009, 05:20 PM   #9
jimbullit's Avatar
`And now-that may make the case for the carbon fiber-again. I read all of the article(s)-I'm impressed-I may have to call the manufacturer-and see what they would charge-I'm thinking at least 1000.00
Who knows anything about carbon fiber? Dom Mustang Audio & Video 18 07-18-2007 04:37 PM
FS: 94-98 Carbon Fiber Hood Kiljosh Mustang Parts for Sale and Wanted 37 02-03-2007 07:37 AM
Carbon Fiber wheels? I_luv_HP&trq Mustang Wheels & Tires 1 08-08-2006 06:31 AM
anybody want some carbon fiber??? fast64 The Bar 3 05-26-2004 11:03 PM
Carbon Fiber Laser02 Mustang Audio & Video 10 02-21-2004 07:46 PM
03:54 PM
